Outer Valve Body Plate Gasket - TCCoA Forums
post #1 of 9 (permalink) Old 09-29-2003, 11:00 PM Thread Starter
Do you have to replace the outer valve body plate gasket (small plate on bottom of valve body) when putting it all back together, or can you reuse is assuming it's in good condition? Thanks guys.
chadg is offline
post #2 of 9 (permalink) Old 09-30-2003, 07:15 AM
rustyul's Avatar
I asked the same question a while back....all I got was "why did you take the outer plate off?" I replaced it instead of re-using it...you really don't want to have to go back in just to replace a $12 gasket...do you?
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #3 of 9 (permalink) Old 09-30-2003, 09:50 AM Thread Starter
I thought it had to come off, seeing as bolts go through it to hold the valve-body in.
I guess I'm just silly for removing all of them.
chadg is offline
post #4 of 9 (permalink) Old 09-30-2003, 10:14 AM
If you took it apart to the point that you're looking at the paper gasket you should probably replace the gasket. I did. Thankfully the Ford dealer that's only 5 minutes away from me had it in stock. I always try to start un-familiar projects earler in the day to account for those unexpected parts runs.
Marcus
Marcus is offline
post #5 of 9 (permalink) Old 09-30-2003, 11:01 AM
jturmel's Avatar
Chad if you need any help with any of this shoot me an email.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #6 of 9 (permalink) Old 09-30-2003, 12:14 PM Thread Starter
Will do good sir, thanks for the offer. I'm still waiting on the stang VB from Dan. Then i'll figure out if that plate gets reused or not and if I even need to worry about this. I guess this is why I bought the service manual...
chadg is offline
post #7 of 9 (permalink) Old 09-30-2003, 12:26 PM
JustinH's Avatar
the torque wrench is your friend on those valve body bolts. There is also a torque sequence, but I didn't go that far, just torque spec.
JH
JustinH is offline
post #8 of 9 (permalink) Old 09-30-2003, 03:09 PM
100in lbs is around 8ft lbs
And I bought the gasket.. Figure this.. if its coming out... and you have to release the pressure from the bolts on the gasket.. change it.
Who knows.. it might save ya a headache later on down the road.
Rotordemon20B is offline
post #9 of 9 (permalink) Old 09-30-2003, 08:54 PM
Silver95Bird's Avatar
check my article in WIP for torque sequence info.
Silver95Bird is offline
