auto to manual - TCCoA Forums
post #1 of 13 (permalink) Old 09-30-2003, 09:49 PM Thread Starter
auto to manual
ok i know somone has posted this before but id like to know what ill need . is there anything special so far the parts i need are driveshaft, trans, clutch pedal, flywheel, clutch, crossmember, ....
which trans is the best to use or which is the only to use?
is it cable clutch or hydrolic (spelling) ?
is the brake pedal changed in the manual cars to smaller pedal?
anything i got confused or missing...
also how do i get the saftey switch wired ?
thanks for any info... i hope to take pics and have all info on a site. any info will be greatly helpful.
90cat is offline
post #2 of 13 (permalink) Old 09-30-2003, 09:54 PM
JustinH's Avatar
Sniff around the tech articles for a while, papajohn wrote a huge article on how to.
JH
JustinH is offline
post #3 of 13 (permalink) Old 10-02-2003, 09:59 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Find a super coupe 5speed donor car. Since your car is a 3.8, you can bolt up the SCs M5R2 tranny, use the driveshaft, pedals and lutch hydraulics. Basically a bolt in swap.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #4 of 13 (permalink) Old 10-02-2003, 01:02 PM Thread Starter
ahhhhh M5R2 thats what i was looking for. does ford make this trans or is it another company. and another question is do these break easily . i herd th t5s can break . is there another tranny aftermarket or from another car that would work.
hmmm.... 6 spd. ..............
90cat is offline
post #5 of 13 (permalink) Old 10-02-2003, 01:58 PM
Sheepish
AverageJoe's Avatar
The M5R2 will nearly be a completely bolt in swap. The M5R2 is actually a Mazda piece and I'm pretty sure it has a higher torque rating than the T-5.
post #6 of 13 (permalink) Old 10-02-2003, 02:11 PM Thread Starter
dou know if the crossmembers are different? between the auto and manual.
90cat is offline
post #7 of 13 (permalink) Old 10-02-2003, 02:13 PM
Sheepish
AverageJoe's Avatar
Unless I'm mistaken they're the same, although the tranny mount may be different. I'd ask over on www.sccoa.com
post #8 of 13 (permalink) Old 10-02-2003, 03:36 PM
kenshi's Avatar
So the M5R2 and T45 are different trannies? I've heard the T45 is hell to get in (and expensive). So if I bought a dead Supercoupe with a good tranny, I'd have pretty much everything I need?
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #9 of 13 (permalink) Old 10-02-2003, 03:42 PM
Sheepish
AverageJoe's Avatar
If you bought the complete car, yes. What you need consists of the tranny, driveshaft, flywheel/clutch assembly, and the clutch hydraulics along with the pedal. The center console is a good thing to snatch as well.
post #10 of 13 (permalink) Old 11-08-2005, 09:12 PM
Smile tranny
the M5R2 is a ford made transmission ford made mazda's transmissions
thekillerkiwis is offline
post #11 of 13 (permalink) Old 11-20-2005, 12:38 PM
In my opinion, the T45 wasn't that bad to get in, and I only spent $1500 on my swap including a rebuilt cobra trans, but it only bolts up to a 4.6L, not the 3.8.
Mike
post #12 of 13 (permalink) Old 11-20-2005, 12:42 PM
Raoul Duke
cougarcragar's Avatar
Interesting. I always read that the M5R2 was a Mazda transmission.
1996 Mercury Cougar XR7
cougarcragar is offline
post #13 of 13 (permalink) Old 11-20-2005, 06:43 PM
Mark M. TCCoA VP's Avatar
The cross members are not the same. The stick cross member hooks onto the exhaust more forward. Some one has to have some pics as my car is away for the winter and pics can not be had until spring.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
