Flickering tranny temp gauge - TCCoA Forums
post #1 of 4 (permalink) Old 10-02-2003, 09:22 PM Thread Starter
I finally got the gauge pod installed with a set of AutoMeter gauges thanks to Gagfish. The tranny temp gauge seems to be acting up though. At first the temp would rise slowly then once it reached around 160* it would start to be affected by braking or accelerating, jumping up and down. John thinks it might be a bad gauge. Anything else to check? Not sure if this is the right forum for this problem, so feel free to move it. Thanks.
post #2 of 4 (permalink) Old 10-03-2003, 12:14 AM
check the ground if it has one, not too familar with the guages...
sc0tty8 is offline
post #3 of 4 (permalink) Old 10-03-2003, 07:13 AM Thread Starter
Question about grounding. In Fubarian's thread in the WIP forum it's mentioned a few times about grounding the sender. Could this be the problem? If it is, any tips on doing it?
Fubarian's ghetto fitting
post #4 of 4 (permalink) Old 10-06-2003, 08:58 PM
Trumpeter Extraordinaire
IronChopz's Avatar
I found this article a while back; it may be worth reviewing, though it doesn't say anything about grounding the sender. However, in the instructions on the gauge I plan on installing, it states to ground the gauge itself to the engine block.
Quoted: "For the most accurate reading, connect the gauge ground wire directly to the engine block, to ensure that there is a good ground between the sender and the gauge."
Just a thought....
IronChopz is offline
