TV Cable Disaster - TCCoA Forums
post #1 of 18 (permalink) Old 10-04-2003, 04:05 PM Thread Starter
Angry TV Cable Disaster
It happened. My Daughter had the car and was about 35 miles away when the grommet broke and the TV Cable fell off. She made it home. By that time, the tranny was a wreck. For several years, I've been putting off changing the grommet. Now, my tendency to put things off has cost me $2,000, all for a $2.88 grommet. Warning for everyone reading this - "Change the grommet".
lahowell is offline
post #2 of 18 (permalink) Old 10-04-2003, 04:10 PM
Mark M. TCCoA VP's Avatar
Yep. You are right as I have not changed mine yet. Ticking time bomb.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 18 (permalink) Old 10-06-2003, 06:32 PM
where is this gromment located?
ITHURTZ is offline
post #4 of 18 (permalink) Old 10-06-2003, 08:19 PM Thread Starter
There are 3 cables at the throttle (assuming you have cruise control). The TV Cable is one at the top by itself. It slides into the grommet. As you can see, it will just drop out when the grommet breaks up.
Leroy
lahowell is offline
post #5 of 18 (permalink) Old 10-06-2003, 08:21 PM
Question
Pardon my stupidity but is this grommet used on the 94 4R70W trannys too? and if so where is it? Thanks,
Richard
Richard Dalkranian is offline
post #6 of 18 (permalink) Old 10-06-2003, 08:30 PM Thread Starter
Don't know about '94's and up. They have the AODE vs the AOD's used in '93 and older. I'm sure others know - how about it folks?
lahowell is offline
post #7 of 18 (permalink) Old 10-06-2003, 09:33 PM
Refrigerator Raider Hater
GreenBird's Avatar
Richard
No. The 4r70w uses the computer and the throttle position sensor.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #8 of 18 (permalink) Old 10-06-2003, 09:38 PM
Thank you Greenbird, one less problem to worry about!
Richard
post #9 of 18 (permalink) Old 07-20-2004, 06:10 PM
Okay, this should be made a sticky dammit.
I have missed this little tidbit of critical information and my tranny just bit it. All because of a worn grommet/clip, that is now costing me $1500+ for a rebuild. A used AOD is $500 CDN including freight, so what's the point in going through the trouble of Re & Re with an old worn wrecker tranny.
BTW, if you are still able to get them, the grommets are no longer supplied by Ford, at least not in Canada. If your Car is old enough that it has an AOD and you have never replaced that part, save yourself some huge grief and replace it NOW.
Okay. Done. You can go get one now. Bye.
soop is offline
post #10 of 18 (permalink) Old 07-21-2004, 02:25 PM
Johnny Bling Bling
93 lx's Avatar
lol, i stock them. quite common for all the aod's.
2009 Ford Flex Limited AWD
93 lx is offline
post #11 of 18 (permalink) Old 07-21-2004, 03:38 PM
tbirdbrain's Avatar
at 10:00pm last monday I found myself in front of my lathe making one!
It should be a regular replacement item (like oil) for anyone with one of these cars!
Keep one in the glovebox.
tbirdbrain is offline
post #12 of 18 (permalink) Old 07-21-2004, 04:52 PM
Do you mean the rubber grommet or the brass bushing with the hairclip?
Mike Donley
Mike Donley is offline
post #13 of 18 (permalink) Old 07-21-2004, 07:53 PM
Mike Donley
It's a nylon sleeve that fits over the pin on the cable end and friction-fits into the hole in the throttle body linkage.
Over time, with engine heat and wear, they break down, crack, and fall apart.
soop is offline
post #14 of 18 (permalink) Old 07-21-2004, 08:24 PM
OK, I had a problem with my car not shifting correctly, so I took it to the dealer and they fixed it with a replacement bushing kit. P/N F3SZ 7H303 B. It is a brass bushing that the cable end fits into and a hairpin clip that snaps onto the end to secure it. Costs 1.24.
Mike Donley
post #15 of 18 (permalink) Old 01-23-2005, 12:34 AM
jk69cat's Avatar
just have to add the nylon one is pn eoaz7f330a
mn12 less!
jk69cat is offline
post #16 of 18 (permalink) Old 01-23-2005, 04:22 PM
ITT-BIRD's Avatar
When i had my 87 crown vic i used a tie wrap to hold it into place. Then when i started at ford someone gave me the brass bushing and clip.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #17 of 18 (permalink) Old 02-08-2005, 07:44 AM
Wow, I didn't even know Ford made a metal one. I've always used the 2 piece steel ones from aftermarket. I think a company named Superior Products made them. Good to know since I need one for my car and the Ford ones are cheaper!
icantdrive55 is offline
post #18 of 18 (permalink) Old 02-08-2005, 11:32 AM
I use the nylon ones and keep a spare and a pair of pliers in the glove box.
