another 5 speed changeover ?? - TCCoA Forums
post #1 of 3 (permalink) Old 10-05-2003, 07:21 PM Thread Starter
l need some advise please, l have driven my 93 lx without o/d for 15000 miles, l did not want to push the car over 70mph @3000 rpm in 3rd gear, l have found a 89 s/c 5 speed transmission [changeover kit} what [approx] would my rpm be at 70 mph in 5th gear??? l am looking for better gas mileage, the car has a stock rear end [ax code 5] and 15in wheels thanks very much for any info.
azbill is offline
post #2 of 3 (permalink) Old 10-06-2003, 01:20 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
http://www.302cobra.com/stuff/topspeed.html
The axle code of 5 shows to be an Open 3.27....
The ratios of the 1989 M5R2 manual....
1st Gear- 3.75
2nd Gear- 2.32
3rd Gear- 1.43
4th Gear- 1.00
5th Gear- .75
Reverse- 3.26
Your current AOD has...
1st Gear - 2.40
2nd Gear - 1.47
3rd Gear - 1.00
4th Gear - 0.67
I assumed a tire size of 215/70R15
With your current rear end gears you'll be turning between 2000-2500rpms in 5th gear at 70mph. You could throw in the rear pumpkin out of that 89 5speed car with its 2.73s and make a nice difference.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #3 of 3 (permalink) Old 10-06-2003, 03:24 AM Thread Starter
very helpful,,thank you very much
azbill is offline
