is this wat i need for 3.73 - TCCoA Forums
post #1 of 7 (permalink) Old 01-07-2004, 11:49 AM Thread Starter
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452298978
would u recomend this?>
jjjustin17 is offline
post #2 of 7 (permalink) Old 01-07-2004, 11:55 AM
Cougar Pilot
BlackCat94's Avatar
The install alone is supposed to take 7 hours. So unless you've got a friend that can do it, and knows what he/she is doing and wants to work for cheap. We're talking like a $500 install. If you're really set on buying just the ring & pinion though you can get them for $140 elsewhere.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 7 (permalink) Old 01-07-2004, 11:56 AM Thread Starter
wat else would u recomend ? doing
post #4 of 7 (permalink) Old 01-07-2004, 12:26 PM
Refrigerator Raider Hater
GreenBird's Avatar
Buy the FRPP pumpkin if your going to get 3.73s.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 7 (permalink) Old 01-07-2004, 09:39 PM
Differential Decisions!!!
When I changed my gears, I also changed to a different type of differential. Trac-Locs only last me about 30K mi., before I tear'em up completely. Now I have an Auburn Cone, which is sturdier than the Track-Loc, BUT If you're thinking of an Auburn, I'd recommend the Auburn Pro. I have the regular Auburn, but I could use something with more bias pressure on the cone. More bias pressure = less slippage!
If I ever wear out the Auburn, I Absolutely getting a TORSEN differential!!!!! The Torsen is a "Worm / Wheel" diff. Completely Gear on Gear, no clutches to wear out!!!! It's also the smoothest differential you can buy!!!!!
68COUGAR
68COUGAR is offline
post #6 of 7 (permalink) Old 01-07-2004, 09:45 PM
Hmmmmm......What brand of gears are they? I didn't see that listed. There are only a couple gear manufacturers worth buying from.
Rich95XR7 is offline
post #7 of 7 (permalink) Old 01-07-2004, 09:46 PM
JoeyICU's Avatar
well.....use the ford style diffy.......throw an extra shim in there...its more of a locker then a limited slip....my friend did that...we will see how long the clutches do hold up tho
JoeyICU is offline
