when you say 8.8, did you mean the whole rear end cause if so it would not fit cause mustang don't have IRS only the 99-up cobra does and even that you can't use. The only thing you can probably use is the ring and pinion, i could be wrong there could be other things you can use, i doubt it though
You should be able to use the whole carrier..........but MN12....... your right, the solid axle wont work under the MN12 chassis........and if nothing works at all, the ring gear it self WILL work as long as it is 28 spline {which you said it is} you will be ok
Any solid axle 28 spline Tloc will fit a IRS, but you have to change out the side gears first.
1999 Cobra IRS pumpkin is a direct fit as they are the only ones with 28 spline, 2000 and newer are 31 spline, so their side gears will have to be changed out also.
Does not matter what spline axle one has for a ring and pinion, as long as it is made for an 8.8 rear.
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
