Shift Kits - TCCoA Forums
post #1 of 11 (permalink) Old 01-08-2004, 11:19 AM Thread Starter
Shift Kits
Just curious on which shift kit would be the best to buy or should i do the jmod?
MattsLE97 is offline
post #2 of 11 (permalink) Old 01-08-2004, 11:32 AM
you get the whole search ordeal thrown at ya on this.
J mod it. Better shifting, longer life of tranny. and if you can, throw in a tranny cooler while your at it...even longer life.
97mn-12 is offline
post #3 of 11 (permalink) Old 01-08-2004, 11:34 AM Thread Starter
Ok cool thanks. I know i'm gonna get alot of opinions on this subject but i was heading towards the jmod just seeing if anyone had different opinions
post #4 of 11 (permalink) Old 01-08-2004, 12:51 PM
You will be best served by The Master's "J-MOD"
Maybe someone can help you with part #'s - drill bit size's ect
I can only say, read the procedure over and over, till you are sure
of what is to be done and go at it !!!!!!!!!!!!!!!!! I did mine - and at
first read - I didn't feel I could do it ,BUT everything came together
nicely !! and YES to installing a Trans Cooler B&M makes a nice kit.
Hope this Helps Curt
LST MN-12 is offline
post #5 of 11 (permalink) Old 01-08-2004, 01:05 PM
Anybody ever successfully gotten a shop to do a j-mod?
Avatar28 is offline
post #6 of 11 (permalink) Old 01-08-2004, 04:03 PM
toofast4u's Avatar
Send a message via Yahoo to toofast4u
I just got a performance automantic valve body I still have to install it.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #7 of 11 (permalink) Old 01-08-2004, 07:45 PM
Rolling-Thunder's Avatar
I had a local tranny shop do the J-Mod for me. Brought them print-outs of the pertinent Tech Articles, and they said "no problem". However, they said they weren't sure how long it would take, and gave me an estimate of 3 to 5 hours, at a labor rate of $45/ hour.
Provided all the parts, including a pre-drilled separator plate.
$100 in labor and it was all done.
The Shop was;
Ralph's Transmission Shop
Albany, NY
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #8 of 11 (permalink) Old 01-09-2004, 09:27 AM
Cool. There's a Mr Transmission in the area that was recommended to me. Supposedly they will do custom work like shift kits and stuff, so I'm hoping they'll do a j-mod, TC install, and flush/fill with Mercon V.
Avatar28 is offline
post #9 of 11 (permalink) Old 01-09-2004, 05:27 PM Thread Starter
Does anyone recomend the trans go shift kit over the jmod?? And i was curious if anyone that has done the jmod replaced the 1-2 2-3 accum pistons on the 94's Is it recomended?? And my final question is what does the trans go kit come with?? Parts ect...
post #10 of 11 (permalink) Old 01-09-2004, 06:23 PM
Very few people recommend the Trans-go over the J-Mod.
Yes, you should do the 1-2 and 2-3 accum's on your 94.
Also, you should take advantage of the Search feature here.
I bet if you type in the word "Trans-go" you will find lots of interesting comments.
post #11 of 11 (permalink) Old 01-10-2004, 06:50 PM
Do the J-mod. Trans go isnt recommended over J mod but it is over the B&M tranny products for our cars.
Shawn40th is offline
