new tranny in! but a problem - TCCoA Forums
post #1 of 3 (permalink) Old 01-13-2004, 06:54 AM Thread Starter
SCsmo's Avatar
well for those who read my thread a couple weeks ago, the tranny is in! for those of you who don't, i had to replace my tranny because i broke the output shaft and it shattered the tailshaft. but the new tranny seems to have a problem. when i start the car up in the morning or after the car has been sitting for a while, when i go to shift, especially from 1-2, it is hard to shift, its almost like it doesn't want to. and it feels like the syncros are grinding. but once i drive it like 10-15 minutes it shifts perfectly. anyone no what this might be?
-by the way, its an M5R2! if you couldn't tell.
01- mustang cobra- lazer red -bbk o/r x pipe w/ 40 series, JLT, waiting to install 4.10's
04 ram- ya, its a hemi- [email protected] -sold!!
92 tbird sc- sold!!!- almost made it to the 60ft mark
newest sales rep at Herb Chambers Ford in Braintree, MA, pm me for info
SCsmo is offline
post #2 of 3 (permalink) Old 02-10-2004, 03:55 PM
girdnerg's Avatar
Just a thought, but the older manual trannies used 80-90w gear oil, and the newer manual tranny in my dodge uses 10w-30 engine oil.
Did you put in the right weight oil. If you put in the heavy weight when it needed the light weight, it would take a while to warm up the oil.
I am new to the forum, so if you are one of the specialists, I don't mean to offend.
Rob
girdnerg is offline
post #3 of 3 (permalink) Old 02-10-2004, 04:23 PM
For info's sake, the M5R2 takes ATF fluid.
93SC is offline
