What happened to my trac-lok? - TCCoA Forums
post #1 of 6 (permalink) Old 01-19-2004, 10:04 PM Thread Starter
Eleventeenth Gear Poster
Aaron K.'s Avatar
Angry What happened to my trac-lok?
I installed my FRPP 3.73 rear end this afternoon and once I had the rear up on jack stands I spun one of the rear wheels to see if my e-brake was on. Well it wasnt on and when I spun the wheel the other spun the oppsite way....WTF! Can the TL portion of the rear go bad without any indication? I never felt or heard anything weird from that area. I have an E under AX on the door jam and once I had the old pumpkin out I saw the tag on it read 3L27. Could the car and pumpkin have been tagged wrong?
I'm glad the e-brake wasnt on and I found that out because my old pumpkin was going to Tim B. I he had gone throught all the work to put that in and it didnt have TL I would have felt like and A$$.
Sold = 96 Thunderbird
Aaron K. is offline
post #2 of 6 (permalink) Old 01-20-2004, 08:23 AM
02 Explorer Pioneer
timb's Avatar
Yes the clutch packs can wear out or even the S sping that pushes against them can break. I'm still interested I'll just open it up and see what's inside
Birdless
timb is offline
post #3 of 6 (permalink) Old 01-28-2004, 08:54 PM
Originally posted by Aaron K.
I installed my FRPP 3.73 rear end this afternoon. I spun one of the rear ......and the other spun the oppsite way
Are you referring to the Old diff. or the new one? What you describe is exactly what an OPEN diff. should do. It's also what a trashed Trac-Loc will do! I've trashed 2 Trac-Locs, so I know what I'm talking about. With the first one, there was Nothing left of the friction or seperator plates, except magnetic sludge! The second one was all there, just the friction plates were completely worn out.
Yes that's entirely possible. The tag decodes as a 3.27 Trac-Lok.
68COUGAR
68COUGAR is offline
post #4 of 6 (permalink) Old 01-28-2004, 09:09 PM
Silver95Bird's Avatar
It's definitely a 3.27 Trak-lok rear... but they need frequent fluid changes ( I saw one Ford Spec say 100,000 miles!), otherwise they start working like a 1 wheel peel. My 95 went about 50k before it acted up, then about 50k more before it did it again. I'll be changing the one I install in the 97 at 25k intervals. Sounds like your axle needs a T-lok kit before it's reinstalled.
Silver95Bird is offline
post #5 of 6 (permalink) Old 02-19-2004, 02:26 PM
PCD
Confirmed V6 Nut
What fluid is recommended for a traclok pumpkin?
PCD is offline
post #6 of 6 (permalink) Old 02-19-2004, 05:09 PM
Refrigerator Raider Hater
GreenBird's Avatar
gear oil and friction modifier. The ford spec is 80w90. If you off by 5 on either number it's no biggie.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
