rear output seal replacement - TCCoA Forums
post #1 of 3 (permalink) Old 01-20-2004, 02:12 AM Thread Starter
Question rear output seal replacement
do you know if you have to pull the gas tank down to get the driveshaft out of the way to replace the rear output seal of the trans. When I replaced the trans. I knew it needed to come down but i didnt know if I had to pull it down or not. If I do I will just let it leak for a little while until I can get a lift.
thanks
bluebird74 is offline
post #2 of 3 (permalink) Old 01-20-2004, 05:29 AM
Silver95Bird's Avatar
undo the 4 DS bolts, then the 6 bolts that hold in the IRS, let the pumpkin droop and then youll be able to pull the DS back.
Silver95Bird is offline
post #3 of 3 (permalink) Old 01-23-2004, 01:06 PM
Geek w/Gearhead Complex
Fubarian's Avatar
bingo. It also helps to drop the exhaust. You don't have to, but it sure as hell helps. I just recently replaced mine
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
