ok im stupid - TCCoA Forums
post #1 of 5 (permalink) Old 01-22-2004, 04:52 PM Thread Starter
ZackG's Avatar
ok im stupid
i have a tranny out of the car (upside down) and there's enough fluid to cover up a good amount of the servo's and what not.. WHERE IS THE O'D BAND. its takin alot of time and paper towels (rags) to soak up the holes around the o/d and i cant seem to find it. Thanks
Zack
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #2 of 5 (permalink) Old 01-22-2004, 06:32 PM
Geek w/Gearhead Complex
Fubarian's Avatar
looks like dat
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #3 of 5 (permalink) Old 01-22-2004, 06:36 PM
Fubarian's Avatar
oh, and if you see a plate with a hole next to the OD bore, you'll have to move the OD band over.
Fubarian is offline
post #4 of 5 (permalink) Old 01-22-2004, 06:42 PM Thread Starter
ZackG's Avatar
i dont know where that is, and is the band the t hing at the bottom of the hole?
it looks as if you have to take the accumulator out from the pic.. but i think im wrong
can you point it out where it is on here? im just about to leave it alone
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #5 of 5 (permalink) Old 01-22-2004, 06:45 PM
Fubarian's Avatar
top left -- 2-3
top middle -- reverse
top right -- OD
bottom right -- 1-2
Fubarian is offline
