Anyone install a B&M Hammer shifter in t-bird w/ AOD? - TCCoA Forums
post #1 of 7 (permalink) Old 01-30-2004, 05:10 PM Thread Starter
Just wondering if anyone has installed the B&M Hammer shifter for the Mustang console into a T-Bird? If so, what mods must be done or are there extra parts/pieces that are needed to make it work correctly. Any info would be appreciated...Thanks!
Chris
fordfan65 is offline
post #2 of 7 (permalink) Old 01-30-2004, 06:43 PM
Silver95Bird's Avatar
I've helped install one in a fox body stang before... I had a major issue with the switches and cam plate. Basically the cam plate didn't have bumps big enough to be able to switch one switch w/o switching them both. I had to take the plate off and use a punch to pound out the cams to a height so that it would work half decent. Pretty sad when you realize how expensive they are. Just thought I'd let you know in case you have the same problem.
Silver95Bird is offline
post #3 of 7 (permalink) Old 01-30-2004, 11:25 PM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
Check with dugweed, i believe he has a B&M Hammer
I have one too, but i have a 94-95 Mustang Shifter in a Fox Cat w/4r70w (yeah, quite strange)
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #4 of 7 (permalink) Old 01-31-2004, 03:16 PM Thread Starter
Thanks for the info guys...
post #5 of 7 (permalink) Old 02-04-2004, 12:54 PM
dugweed's Avatar
Send a message via AIM to dugweed Send a message via Yahoo to dugweed
the shifter for 94-95 mustangs w AOD trannies will not work easily, I tried it.
I used a universal B&M hammer shifter and it went in fairly easily, some minor modifications had to be made to the shifter mounting cup to allow correct placement of the shifter in the upper console lid, and some minor clearancing of the lid itself to faciltiate the upper console plate of the shifter to look good.
here are some pictures of my shifter install:
pm or email me if you have any questions or need any advice on how i did this.
Mike
PS you WILL have to use the special B&M AOD shift lever for the trans to get the shifter operate correctly
2009 Harley-Davidson Road Glide
1996 F350 CCLB 7.3 5 speed 4x4
dugweed is offline
post #6 of 7 (permalink) Old 02-04-2004, 05:14 PM Thread Starter
Wow, that looks pretty cool. I was thinking about the universal one maybe being easier to install, but thought the mustang one would be a closer fit. I know B&M says it can't be done because I called their tech line and they said the Mustang console one would NOT fit a t-bird.
post #7 of 7 (permalink) Old 02-05-2004, 04:30 AM
One thing to consider is that the universal Hammer works like a regular shifter from park to drive, then you can ratchat from there. Where as the console Hammer is a full rachet from park to first, and first to park. I've had both, and I like the universal one better. Hope this helps.
cougarman is offline
