Peddles for Manual Conversion - TCCoA Forums
post #1 of 3 (permalink) Old 02-04-2004, 02:37 PM Thread Starter
97Limited Edition TB's Avatar
I know that Tbirds that had maunal trannys had a hydraulic clutch. Will the clutch system off a '94-'95 mustag, which is a cable sysytem,work on our cars for a manual tranny conversion?
'97 Limited Edition Thunder Bird
JBA headers
ART X pipe
MAC underdive pulleys
17X9 Cobra R's
Eibach springs
Koni infinite adjustables
Xenon Ground Effects
97Limited Edition TB is offline
post #2 of 3 (permalink) Old 02-04-2004, 03:44 PM
CobraRThunder's Avatar
It has been done, twice that I know of. Only once that I have seen in person. The one guy talked about doing it in the drivetrain thred here
click me
Skidonenko was the one that said he got it done.
4R70W From DirtyDog
CobraRThunder is offline
post #3 of 3 (permalink) Old 02-04-2004, 05:04 PM Thread Starter
Thanks for the reply Chris.
I will probably be calling on you here in the next year or so when I put the new 351 stroker motor and t-56 tranny in.
Thanks again.
JBA headers
ART X pipe
17X9 Cobra R's
Eibach springs
