Do these actually work like they should? - TCCoA Forums
post #1 of 13 (permalink) Old 02-04-2004, 11:14 PM Thread Starter
http://store.summitracing.com/partde...2D70381&view=1
It's the B&M Shiftplus kit, basically an electronic shift improver, just wondering if anyone has had experience with them!
Thanks!
Hode is offline
post #2 of 13 (permalink) Old 02-04-2004, 11:27 PM
CobraRThunder's Avatar
stay away....FAR away
4R70W From DirtyDog
CobraRThunder is offline
post #3 of 13 (permalink) Old 02-04-2004, 11:32 PM Thread Starter
K, Thx!
Hode is offline
post #4 of 13 (permalink) Old 02-06-2004, 09:47 PM
If the B&M does its "improving" by raising line presssure across the board, it will tend to wear internal seals unnecessarily. If you just have it set to firm to do a pass at the track, and leave it normal the rest of the time, it shouldn't do any harm.
I can't see the harm of raising line pressure just during shifts, but I haven't tried this on mine. I may try this with my next rebuild.
bill_s is offline
post #5 of 13 (permalink) Old 02-07-2004, 08:35 AM
It over heats, will literally melt whatever it touches...I had it for about 6 months before I ditched it and did a REAL tranny mod...Like Bill_s said, if yer just doin' track runs, then it is ok, but leaving it on longer then say 10 mins at a time, it will burn sh*t...trust me, I have a nice burn in my pass. seat from it :-)
Kodiak Kid is offline
post #6 of 13 (permalink) Old 02-07-2004, 10:45 PM
RUN!
WhiteBird101 is offline
post #7 of 13 (permalink) Old 02-07-2004, 11:11 PM
i had one for a while it shifts much harder. the good thing is that you can turn it off. it gets very hot tho so be careful if you get it, ive heard of it starting a fire in someones car mounted in the dash somewhere. if you can get one very cheap and you wanna see the difference the j mod will do then do it i guess. the j mod will shift harder and it doesnt hurt the trans at the same time
rossf83+1 is offline
post #8 of 13 (permalink) Old 05-28-2004, 08:38 AM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
Does it cool down when you switch it back to the stock seting or do you have to unplug it all together, b/c I was thinking about getting one to just have on for passes at the track and leave it switched to the stock setting for everyday driving, but if i cant drive for more than 10 mins on the stock seting without burining my car down then its not worth it.
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #9 of 13 (permalink) Old 05-28-2004, 09:45 AM
Look, it gets hot when you leave it in constant use. But otherwise, when left off its stays cool. I have one sitting here at my place. if you want it I will sell it for $25 shipped. with instructions. It works. Chis
4R70W From DirtyDog
post #10 of 13 (permalink) Old 05-28-2004, 12:05 PM
Not to "sale block" here, but i've always heard bad things about it. If you're going to be doing a transmission mod, you might as well do it right with a shift kit/VB mod, You can do the J-mod for a bit more than 25$
Green95LX is offline
post #11 of 13 (permalink) Old 05-28-2004, 12:07 PM
I have one that I put in my car before I found this website, didn't like it, made the solenoids in the tranny click, but it's still around here somewhere.
Rich95XR7 is offline
post #12 of 13 (permalink) Old 05-28-2004, 02:09 PM
02 Explorer Pioneer
timb's Avatar
There was also someone on this site....I forgot who.....who one a judgement against them and they had to pay for a new trans because of the damage it caused. I agree adding line pressure just during the shift isn't an issue in fact SCT chips do just that
Birdless
timb is offline
post #13 of 13 (permalink) Old 05-31-2004, 11:51 PM
Send a message via Yahoo to BIG PERV
YES run far far away. My friend had one in his truck, and indeed it did catch fire while he was driving on the highway. luckily he was pretty quick off the road so the damage wasn't so bad, but it still sucks.
BIG PERV is offline
