tremec 3550 swap - TCCoA Forums
post #1 of 13 (permalink) Old 02-10-2004, 07:55 AM Thread Starter
tremec 3550 swap
hi this summer im swaping a tremec 3550 into my 94 cougar i need to know how much the drive shaft has to be cut and any other helpful information on it
thanks
medicalmike is offline
post #2 of 13 (permalink) Old 02-10-2004, 08:22 AM
Jedi Master
mn12xr7's Avatar
If I am not mistaken you can use a ford aerostar driveshaft
-Orlando
mn12xr7 is offline
post #3 of 13 (permalink) Old 02-10-2004, 11:09 AM Thread Starter
thanks a lot
post #4 of 13 (permalink) Old 02-10-2004, 11:09 AM
PostSkank
StupidFly's Avatar
I read an aerostar driveshaft will work (aluminium too I believe ) But that was for a 5.0L with a T-5. May not work in your case, dont know for sure
math > pasta
StupidFly is offline
post #5 of 13 (permalink) Old 02-10-2004, 11:13 AM Thread Starter
well the tremec is supposed to be interchangable with the t5 and i have a 3.8 if im right everything for the 5.0 t5 swap should be the same for the 3.8 t5 swaps
post #6 of 13 (permalink) Old 02-10-2004, 11:18 AM Thread Starter
as in the van right what kind of engine does that use
post #7 of 13 (permalink) Old 02-10-2004, 11:29 AM
i'm medicalmikes friend, i'll be helping him with the tremec swap over the summer, how much horsepower will the aerostar driveshaft support? because we dont wanna break it after we put in the 5.0 and a blower
respectirocz is offline
post #8 of 13 (permalink) Old 02-10-2004, 02:11 PM
Jedi Master
mn12xr7's Avatar
it should work cause the t-5, tremec tko, and the 3550 are the same length, on my buddy's stang we used the same driveshaft. If you are shady about the van's driveshaft, get one cut to those specs cause ordering one to be made fresh will cost you a pretty penny
-Orlando
mn12xr7 is offline
post #9 of 13 (permalink) Old 02-10-2004, 03:52 PM
the only problem with shortening the stock driveshaft to the appropriate length, is finding a driveshaft in the area, can u believe this? new york city and we cant find a driveshaft shop? what the heck
post #10 of 13 (permalink) Old 02-10-2004, 03:56 PM
Jedi Master
mn12xr7's Avatar
there's one in my area, el paso if you want we can make arrangements to get you one
-Orlando
mn12xr7 is offline
post #11 of 13 (permalink) Old 02-10-2004, 04:13 PM
thanks for the offer, i think we should first try not to inconveniance anyone, we'll keep all our options open
post #12 of 13 (permalink) Old 02-12-2004, 11:52 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
moved to drive train from events?!?!?
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #13 of 13 (permalink) Old 02-12-2004, 12:26 PM
Jedi Master
mn12xr7's Avatar
lol
-Orlando
mn12xr7 is offline
