Differential Cover - TCCoA Forums
post #1 of 3 (permalink) Old 02-11-2004, 10:06 PM Thread Starter
96bird's Avatar
Differential Cover
I am interested in this piece. I would like to see what other people's opinion is on it. It is an HD differential cover that should increase the strength of our rearends. As far as I can tell it should mount on a tbird just like it would the cobra. Check this thread out for the full story.
Cover
Russell
96bird is offline
post #2 of 3 (permalink) Old 02-12-2004, 06:29 PM
392Bird's Avatar
If it works for that series Cobras, it will work for our. I WILL get one for mine before hitting the strips this Spring.
Good find, thanks
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #3 of 3 (permalink) Old 02-12-2004, 07:18 PM Thread Starter
96bird's Avatar
No problem. I thought that it would be a good idea for anyone that was running major power and/or hooking up hard.
Russell
96bird is offline
