Trans shutter in OD - TCCoA Forums
post #1 of 15 (permalink) Old 02-13-2004, 05:24 AM Thread Starter
Cool Trans shutter in OD
Folks my '97 4.6 Sport model's transmission just yesterday started shuddering kind of weird when going into the OD gear it happened all of a sudden, and also after switching to "OD OFF" it goes into 3rd gear kind of weird as well almost like it doesn't go in completely the first try then goes in a second time type feeling.
Is this the 4r70w like I have in my '94 F150 behind the 302? or something else?
Car only has 53k original miles we are the second owners no racing or rough use, fluid and filter was changed 2 years ago when we bought it, any ideas?? THANKS!!
Pearl97LXSPORT is offline
post #2 of 15 (permalink) Old 02-13-2004, 09:14 AM
Silver95Bird's Avatar
Drain the pan and the Torque Converter via the plug, replace with Mercon V fluid and add a transmission cooler to extend the tranny's life. If this does not solve the problem, the TC should be replaced. Chances are on a 97 it's still got lots of life left yet, theyre a little better than the 94-5 ones.
Silver95Bird is offline
post #3 of 15 (permalink) Old 02-13-2004, 04:38 PM Thread Starter
I've heard of Mercon V fluid, but how is it different from the regular Mercon/Dextron, and when you say drain the t/c shouldn't I remove the pan and change the filter as well?? its really the only thing I know to do on this trans.
if it were older I'd change the vacuum modulator valve but I guess thats out of the question anymore.
I've heard that this type of problem could be caused by the valve body coming loose and just needs to be re-torqued, what do you know about that? Thanks!
post #4 of 15 (permalink) Old 02-13-2004, 06:56 PM
Yes, it's a good idea to change the filter when you remove the pan. Mercon V is a semi-synthetic fluid which better protects the parts inside against the heat in the transmission.
FYI: The valvebody at this kind of mileage won't come loose on its own. If it's ever removed and reinstalled, it should be properly torqued 3 times in the proper sequenece. I've done it this way several times, and never once have I ever had to retighten them.
At first all this electronic stuff will appear overwhelming, but once you get used to it I think you'll come to like it.
post #5 of 15 (permalink) Old 02-14-2004, 04:13 AM Thread Starter
Ok, So can you tell me what trans I've got? the trans code is "L" is this in fact a 4r70w? Thanks!
post #6 of 15 (permalink) Old 02-14-2004, 04:27 AM
You have a 4R70W.
Matt S. is offline
post #7 of 15 (permalink) Old 02-14-2004, 06:27 PM Thread Starter
Thanks everyone!!!! I picked up a trans filter kit and some valvoline Mercon V fluid tonight and will change tomorow and advise.
post #8 of 15 (permalink) Old 02-15-2004, 04:10 PM Thread Starter
Cool
Just wanted to report that my problems are solved!!!!!!
Changed filter and fluid (including the t/c) went with Valvoline's Mercon V fluid, shifte get better with each one!!!!
Thanks very much for the suggestion!!!!!
post #9 of 15 (permalink) Old 02-16-2004, 09:23 PM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
im glad i read this, i have the same prob, i guess im gonna do a lil trans work here soon and i have an electronic shift kit on its way, only $40 from jegs and it should help some also
Warlockguitarman is offline
post #10 of 15 (permalink) Old 02-17-2004, 12:47 AM
Fry Rice Specialist
Casper's Avatar
ditch the electronic shiftkits(if it is the B&M shift improver kit). it just raise the line pressure in your transmission and it is VERY BAD for your tranny. it'll kill your tranny in no time.
CarDomain Page
Casper is offline
post #11 of 15 (permalink) Old 02-17-2004, 01:21 AM
so the shift kit isnt a good idea, here is a link to wut im talkin bout http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361 if this is no good wut would you suggest to do to get a better shift and do everything that this product claims to do
post #12 of 15 (permalink) Old 02-17-2004, 03:22 PM
What you want is the J-mod. chapters 13 and 14 of the OD 101 tranny article. Also the other 2 of the top 3 tranny articles for info on installing it.
post #13 of 15 (permalink) Old 02-21-2004, 06:02 PM Thread Starter
Cool
UPDATE: Wife has been driving the car all week, all is good I think, except possibly 3rd gear, its MUCH better than before, but I think it could stand to be a bit firmer of a shift (the 1-2 are great as are 3-4) should I consider the J MOD?? can someone please guide me to where I can read up about it?
And is the B&M electronic shift kit really so bad?? Thanks!
post #14 of 15 (permalink) Old 03-02-2004, 10:54 PM
As I understand, the B&M shift kit raises line pressure across the board, which will work for firmer shifts, but the excess pressure wears the servo seals more than necessary, so you will be paying for a rebuild sooner. The higher pressure also generates more heat and load on the pump. The PCM maintains line pressure just high enough to keep the clutches from slipping, given the torque the engine is making. The Jmod speeds up the clutch and band engagement/disengagement without messing with the line pressure. It is the way to go & worth the extra effort.
bill_s is offline
post #15 of 15 (permalink) Old 03-03-2004, 12:20 AM
Sweet T
SanDiegoLXBird's Avatar
... And with proper tools it can be done in about half a day if you feel like taking a couple beer breaks
1994 SC 5-Speed
SanDiegoLXBird is offline
