3.73 - TCCoA Forums
post #1 of 6 (permalink) Old 02-16-2004, 08:39 PM Thread Starter
3.73
I am going to buy a set of ring and pinion 3.73 gears. I have a guy to install them in the spring but do I need anything else but the gears and maybe a rebuild kit??
My car does not have traction lock either.
whitecat7 is offline
post #2 of 6 (permalink) Old 02-16-2004, 11:31 PM
Refrigerator Raider Hater
GreenBird's Avatar
If you want it to have Trac-lok now would be a good time to buy the kit.
Unless your getting a deal on the labor, it would probably be cheaper to buy the FRPP pumpkin. Justin H is selling some now for $585 shipped, IIRC.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 6 (permalink) Old 02-17-2004, 06:36 PM Thread Starter
I am getting a great deal on the labor actually. But thanks for the advice.
post #4 of 6 (permalink) Old 02-17-2004, 10:17 PM
The Great Obucina's Avatar
i would get a trac lok, you can usually find one on ebay for 50-70$ or so. Also, contact Dan and get the master install kit M-4210-B its 80$ or so and has all the bearings and pinion hardware.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 6 (permalink) Old 02-18-2004, 02:02 PM
Send a message via AIM to Kleckner
A Trac-lok will transform the way your car drives. Especially with a 3.73:1 gear. It is worth the little extra cash to get a trac-lok if you are going as far as rebuilding the diff and putting new gears in.
Kleckner is offline
post #6 of 6 (permalink) Old 02-19-2004, 05:55 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
I'd pick up a used trac lok, get new clutches for it and throw it in at the same time.
A quick note about the 8.8" master rebuild kit. From Dan is like $71, but it does NOT include the inboard and outboard axle bearings and seals. You'd have to buy those separate.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
