j-mod EPC and slipping - TCCoA Forums
post #1 of 6 (permalink) Old 02-20-2004, 12:59 PM Thread Starter
rbrown's Avatar
I am about to fix my problem with 1-2 accumulator and figure since I am in there.
My question is this. I read about the EPC buzzing and mine has done this for years. I want it gone. The sheets mention going to a newer control valve. Are they referring to the EPC valve only? And where is it to replace. It sounds like it is on the outside of the tranny.
And I really hope this solves the slipping/sticking 1-2. It has been a hard shift for 2 years and only started slipping yesterday.
And man all these drills are hard to find!
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #2 of 6 (permalink) Old 02-20-2004, 05:34 PM
On Probation
blown96bird's Avatar
I think that you have to use the same type epic silonoid as came with your car. I think that the resistance is diffrent for the 96 and up units and if you use it it coul ruin your transmission or computer. I would reread the article again
blown96bird is offline
post #3 of 6 (permalink) Old 02-20-2004, 10:09 PM
3rd Gear Chirper
hotbird's Avatar
EPC solenoid is inside transmission case, next to the manual lever. Drop the pan and you should see it up there.
hotbird is offline
post #4 of 6 (permalink) Old 02-21-2004, 05:19 PM Thread Starter
rbrown's Avatar
looks like Ford only has the f6XXXXX partnumber. It lists it for the 95 so that is what I will go with.
Thanks.
I hope it works as well as I think it should.
*Rodney*
rbrown is offline
post #5 of 6 (permalink) Old 02-22-2004, 10:14 PM
Silver95Bird's Avatar
The 1-2 accumulator will fix the slipping/strange 1-2 shifts. the thing about EPC's is that there are like 3 different brackets, because the valve bodies and EPC's changed through the years. The valve bodies changed thickness, so if you try to use the wrong bracket/EPC they wont fit right. The EPC's have 2 different shapes if i recall correctly. I think the early bracket only works with the early EPC, but I could be wrong. Definitely check the article and the parts supplier to make sure youve got the right one before you buy, a lot of places wont do returns on electrical stuff.
Silver95Bird is offline
post #6 of 6 (permalink) Old 02-22-2004, 10:50 PM Thread Starter
rbrown's Avatar
I bought the EPC which lists itself as a 96 part. Updated I would presume. But I didn't use it. It was definitely the accum. The spring was in 3 pieces and the bottom retainer plate was just flopping around. There would be little if any pressure in that area.
I will take the EPC back tomorrow. The parts guy assured me he would take it back if I didn't use it. I wasn't going to take it unless he would. I didn't want to get in there on a weekend and need it and have no place to buy one or a way to get there.
*Rodney*
rbrown is offline
