FYI be sure to check you rear wheel bearing - TCCoA Forums
post #1 of 3 (permalink) Old 02-20-2004, 05:55 PM Thread Starter
On Probation
blown96bird's Avatar
Be sure to cheeck your rear wheel bearings if you car has 100k miles or you have a vibration you can not eliminate. I was changing my drag radials back to street tires and notice that my passanger side rear wheel move horizonily when I was torquing the wheel. I went ahead and pushed in at the top and pulled out at the bottom with the wheel off the ground and wiggled back and forth and noticed movement where there should not have been any. I checked my driverside and it checked ok. I replaced the wheel bearing and found it was totaly shot on the passangerside rear. If I had not it could have caused catrostropic failure. It was causing the vibrtion that I could not get rid of. It is much smoother now. I will replace my driverside next week since it has 100k on it also.
blown96bird is offline
post #2 of 3 (permalink) Old 02-21-2004, 10:47 AM
Exclamation
I had one fail too. Only 60k mikes. i was gettign my lowering springs and the gywas like feel this. WOAH! so we had to fit to get the new bearing in it was a bear to press it out scared trhe aluminum would break anyways we got it replaced and I have two rear lowering springs waiting for the front to gto on now. Good thing you caught it. I would never know on mine unless the whole thing was shot.
PerformanceWhite 97 Tbird LX loaded
67,000 miles
4.6 v8 with motor and exhaust upgrade
Custom Interior, Exterior and Audio
wanna be racer
1972 Cutlas Supreme 55,000 miles HO 5HIT (liscence plate)
1979 Cutlas Supreme T-top Hurst/Olds Clone, 461 Olds
Hot wheels
reckmann is offline
post #3 of 3 (permalink) Old 02-21-2004, 12:17 PM
Cougar Pilot
BlackCat94's Avatar
How much did that run you for parts?
I will probably have to do both of mine soon enough. Is it fairly hard to do? Time consuming? Thanks.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
