Ford's own friction modifier for ATF? - TCCoA Forums
post #1 of 2 (permalink) Old 02-22-2004, 09:49 AM Thread Starter
ortbird's Avatar
Question Ford's own friction modifier for ATF?
Hi again,
it's time for my ATF change again, and this time I'm getting a drain/refill of tranny incl. TC, using Merc-V, and replace the filter(last time was a power flush, and the filter was not changed).
I've seen in a Ford tech forum that Ford has a friction modifier that can be added to the Mercon to reduce the TC shudder even further(I have a little amount of tc-shudder, I think, but not too bad)
Does anyone know of this product?
or have a part number?
or should I just use Merc-V?
any info would be thankfully welcome
Also:
--are you guys using mercon-V as PS fluid or just the reg.Mercon?
--has anybody used/know of a product called "Dr.Tranny's instant shudder-fixx"? I think it's made by Lubeguard
ortbird is offline
post #2 of 2 (permalink) Old 02-22-2004, 10:25 AM
JustinH's Avatar
no, use mercon V, no additives, nothing else.
Change it every 15k and keep it cool and you will have no problems.
JustinH is offline
