bypassing radiator - TCCoA Forums
post #1 of 5 (permalink) Old 02-24-2004, 12:36 AM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
bypassing radiator
i plan to bypass my radiator when i hook the hoses up to my transcooler. what should i use to plug up the exposed holes where the metal tranny lines go in the radiator? is there some sort of screw-on cap to use?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 5 (permalink) Old 02-24-2004, 11:09 AM
Sweet T
SanDiegoLXBird's Avatar
I didn't bother, as far as I know the "trans cooler" on most radiators is just a bit of piping that's exposed to the coolant, nothing big and nothing that'll allow crap into the radiator core.
1994 SC 5-Speed
SanDiegoLXBird is offline
post #3 of 5 (permalink) Old 02-24-2004, 11:53 AM
If i were you i would take out the big nut the goes into the radiator were you hook up your metal line and take it to a hardware store and put a bolt and just put some thread tape on just incase it were to leak
MattsLE97 is offline
post #4 of 5 (permalink) Old 03-02-2004, 08:41 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
just get some plastic plugs, goto lowes....
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #5 of 5 (permalink) Old 03-03-2004, 12:39 PM
I bypassed my rad when I installed a B&M style trans cooler. I plugged the holes on the rad with bolts so any fluid left in there could not leak out on my floor. Good luck
vancouverBC is offline
