Deflection of Differential - TCCoA Forums
post #1 of 4 (permalink) Old 02-24-2004, 09:44 AM Thread Starter
97Limited Edition TB's Avatar
How much axial deflection,side to side from axel input shaft to axel input shaft, does our diffentials with a traction locker and a pinion brace have under hard acceleration and say with a motor at about 500 ft*lbs of torque?
I know that this cannot be exactly measured, but I was wondering if anyone had a idea of how much it would be.... 1/4", 1/2", 3/4", 1"????
'97 Limited Edition Thunder Bird
JBA headers
ART X pipe
MAC underdive pulleys
17X9 Cobra R's
Eibach springs
Koni infinite adjustables
Xenon Ground Effects
97Limited Edition TB is offline
post #2 of 4 (permalink) Old 02-24-2004, 12:25 PM
I would guess it's pretty minimal. Personally, I am more concerned with deflection and flex at the knuckles. Just take a look at those pressed upper control arms and pressed/tacked IRS subframe. They have "twist me" written all over them.
Blown306 is offline
post #3 of 4 (permalink) Old 02-24-2004, 12:57 PM Thread Starter
The reason why I am interested what the deflection is from side to side for the differential is b/c I am making some bracing for the subframe. I have a brace about 1/2" away from the bottom of the axels on the section in between the differential and the CV joint. This section of the axel may interfear with the additional bracing if the differential deflects from side to side.
JBA headers
ART X pipe
17X9 Cobra R's
Eibach springs
post #4 of 4 (permalink) Old 02-24-2004, 08:11 PM
What if you used a dial indicator on a magnetic mount. you could set it to hold highest reading, then beat the he!! out of the car, check the guage.
Just a thought
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
