FRPP swap - TCCoA Forums
post #1 of 19 (permalink) Old 03-02-2004, 05:12 PM Thread Starter
Send a message via AIM to chrisnack
FRPP swap
Do I need anything else besides the pumpkin and friction modifier?
I assume if you are careful, you need nothing else. MMX shaft is going in at the same time.
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #2 of 19 (permalink) Old 03-02-2004, 05:22 PM
JustinH's Avatar
The pumpkin I sell has fluid in it already, but I like to drain it out and refill with mobil1 and friction modifier.
Take a good look at your IRS bushings, you might want to replace them.
You will need a speedometer gear to correct your speedometer, your 4r70w equipped car needs a purple one from the dealer. Its a six dollar item if my mind serves me right.
JH
JustinH is offline
post #3 of 19 (permalink) Old 03-02-2004, 05:28 PM Thread Starter
JH
Well your selling me the pumpkin. (Whenever my damn check arrives) I'm a man of my word, and I told you I'd grab one of those pumpkins from you awhile back.
I have a bottle of friction modifier and the correct speedo sitting around.
Thought about the bushings. MN12Performance has the IRS bushings for $40.
NSN Motorsports
'96 Eagle Talon ESI
post #4 of 19 (permalink) Old 03-02-2004, 05:32 PM
JustinH's Avatar
i would just call dan newman, and get everything from him.
JustinH is offline
post #5 of 19 (permalink) Old 03-02-2004, 05:34 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Justin, when you say they come full with "fluid", do you mean just the gear oil, or do you mean the gear oil AND the friction modifier?
Sold = 96 Thunderbird
Aaron K. is offline
post #6 of 19 (permalink) Old 03-02-2004, 05:35 PM Thread Starter
Get what from him?
The bushings? the $40 ones were poly.
NSN Motorsports
'96 Eagle Talon ESI
post #7 of 19 (permalink) Old 03-02-2004, 05:54 PM
JustinH's Avatar
They are filled with ford spec gear lube and the proper mixture of modifier from the factory.
I dump that stuff out and go with mobil1 or royal purple.
JH
JustinH is offline
post #8 of 19 (permalink) Old 03-02-2004, 05:56 PM
JustinH's Avatar
Originally posted by chrisnack
Get what from him?
yeah, get the bushings and the other stuff that was mentioned, unless you already have it.
JustinH is offline
post #9 of 19 (permalink) Old 03-02-2004, 07:50 PM
The Great Obucina's Avatar
Get what from him?
contact Jeff and www.nitrostangracing.com and get the Steeda poly bushings, mine were 36$ after tax since i went to his house to pick them up. Only thing you have to do is get the PN from steedas site.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #10 of 19 (permalink) Old 03-02-2004, 11:53 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
I'm also about to swap to the frpp rear. how many quarts of rear end oil do i need and how many bottles of friction modifier? thanks
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #11 of 19 (permalink) Old 03-03-2004, 12:48 AM
T-bird4vr's Avatar
Send a message via AIM to T-bird4vr
Probably an alignment when you are done. But that depends on how you take stuff apart.
Julian
twin screw sc
T-bird4vr is offline
post #12 of 19 (permalink) Old 03-03-2004, 01:13 AM
Frank
Last weekend it was about 1.5 quarts of gear lube and 4oz of friction modifier.
93SC is offline
post #13 of 19 (permalink) Old 03-04-2004, 12:00 PM
toofast4u's Avatar
Send a message via Yahoo to toofast4u
Do u still have any of them rears justin?
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #14 of 19 (permalink) Old 03-04-2004, 01:07 PM
One items not mentioned yet are the hub/half-shaft nuts.
I believe they are not reusable and they probably aren't available at the local parts stores.
69 F100 LWB w/460 Engine
post #15 of 19 (permalink) Old 03-04-2004, 09:21 PM
i ran into the same problem with the front hub nut...the rears are about 7$ from Ford...im lucky enough to have the warehouse in town so i get it really cheap or have it Will Called for me
joseph
post #16 of 19 (permalink) Old 03-04-2004, 10:27 PM
Justin,
You sell the pumpkin? is it an 8.8 with 3.73s???
if so... I'm interested
tsbird1994 is offline
post #17 of 19 (permalink) Old 03-05-2004, 10:47 AM
toofast4u's Avatar
tsbird1994 u been pmed
post #18 of 19 (permalink) Old 03-05-2004, 01:37 PM
Overkill Fetish Freak
While they are not re-useable they can be found in most any parts stores.
Dr. FrankenCougie is offline
post #19 of 19 (permalink) Old 03-05-2004, 02:10 PM
JustinH's Avatar
Originally posted by tsbird1994
Justin,
Yes, and yes.
I sent you a pm.
JH
JustinH is offline
