Tranny Cooler Install Questions - TCCoA Forums
post #1 of 10 (permalink) Old 03-03-2004, 06:13 PM Thread Starter
Bought a 28K Tranny Cooler kit the other day from NAPA (I think it's actually a Hayden model.).
Came with a few feet of hose, zip ties, hose clamps, and the cooler.
Now, here's the problem...I can't seem to find the XMSN fluid lines going into or out of the radiator. Help!
I plan on putting it between the radiator and the A/C condenser (yes, I am going to cheese out by using the zip ties), but until I find those lines, I'm kind of stuck.
Can someone tell me where to look? High, low, driver side, passenger side, etc...?
John
'96 T-Bird LX V8
Jacksonville, FL
If you live in Jax and want call me, my number is (904) 629-1811.
Loc-Nar is offline
post #2 of 10 (permalink) Old 03-03-2004, 06:19 PM Thread Starter
Sorry. I'm going to put it in front of the A/C condenser (not behind it).
Loc-Nar is offline
post #3 of 10 (permalink) Old 03-03-2004, 06:44 PM Thread Starter
OK. I think I found them:
Two hard lines. Both on the Driver's side on the back side of the radiator. They meet up, and then go off to who-knows-where under the engine together. The top one was the cooler one after I ran the engine in Drive with the brake on for a few seconds (the lower one almost burned me, so I'd say that this is a more than worthwhile mod).
My kit came with a 5/16" quick disconnect too. I guess that I am supposed to unhook the return line, put the new quick disconnect in there. Attach one hose piece to there with the other end on the cooler. Attach the other hose piece to the cooler's outlet, and then hook it up to the return line. Right? Somebody stop me if I'm going to screw something up. Thanks.
Loc-Nar is offline
post #4 of 10 (permalink) Old 03-03-2004, 06:45 PM
TCCoA Founder
Sir William's Avatar
The lines enter the tranny at the top and bottom of the drivers side of the radiator. The easiest place to splice into the line is where it runs across the front of the engine. Just cut one line and push tubing onto each end. Nice and easy. Be sure to push the tubing 3" - 4" onto each hard line and use two clamps on each hose.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #5 of 10 (permalink) Old 03-03-2004, 06:59 PM Thread Starter
OK. Was I right about the top one being the return line? It was still pretty warm, but not nearly as hot as the bottom one.
So, I guess I'll cut a section out of the return line, put the hose pieces on there about 3-4" back, and clamp them down. Then I'll mount the cooler vertically on the A/C condenser with the openings to the bottom for easier routing of the tubing. Sorry. Thinking out loud here.
I always overthink this crap. Afraid I'm going mess something up...
Thanks for the patience/help.
Loc-Nar is offline
post #6 of 10 (permalink) Old 03-05-2004, 09:29 AM
MaleWhore
smokymance's Avatar
ok ...so top is the return line...and one question...how much fluid loss will accour installing this cooler... im doing mine this summer, but i just changed my tranny fluid...i dont want to do it again...
smokymance is offline
post #7 of 10 (permalink) Old 03-05-2004, 11:14 AM
GUS
I thought the bottom one was return?
GUS is offline
post #8 of 10 (permalink) Old 03-05-2004, 12:59 PM
3rd Gear Chirper
hotbird's Avatar
Yup, top is return line, and you're doing everything right. Personally, I just disconnected the radiator cooler and ran the cooler lines right into my aftermarket cooler. There is no sense in using the radiator cooler in Florida, as this just puts an additional load on the engine cooling system, and will actually REHEAT the trans oil. Another suggestion is to add a transmission temperature gauge, so you can keep an eye on things.
hotbird is offline
post #9 of 10 (permalink) Old 03-05-2004, 04:14 PM
MaleWhore
smokymance's Avatar
how much fluid would drain out when removing the lines from radiator to the new cooler....
post #10 of 10 (permalink) Old 03-05-2004, 07:21 PM
I would say under a half quart, not gushing out or anything.. It will spray out if you start the car up, so just get a rag and plug it while you get ready to install the cooler.
RyanG is offline
