FFRP rear question - TCCoA Forums
post #1 of 7 (permalink) Old 03-04-2004, 10:41 PM Thread Starter
toofast4u's Avatar
Send a message via Yahoo to toofast4u
FFRP rear question
Ok here we go right now I have 3:08s I'am going to a FFRP rear with 3:73s do I need a chip? I'am going to get one when I get more cash but will I have probs if I put the rear in before the chip? Thanks.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #2 of 7 (permalink) Old 03-04-2004, 11:09 PM
Send a message via AIM to chrisnack
Yup, too many steps for your EEC to compensate for.
Your gonna be smacking the rev limiter. It's going to rev up quicker than the computer is used to, therefore it won't fill the cylinders in the tranny fast enough, so it will bounce off the limiter, and then shift.
Plus your top speed will be like 90, if not lower since you have 3.08s
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #3 of 7 (permalink) Old 03-08-2004, 08:51 AM
what about going from 3.27's to 3.73's ? i have heard you dont need a chip, is this true? if so i will go ahead and swap to the frpp. just curious.
97ThunderCat is offline
post #4 of 7 (permalink) Old 03-08-2004, 09:05 AM
96bird's Avatar
You shouldn't need a chip with a 3.27 to 3.73 gear change. You will just need a speedo gear.
Russell
96bird is offline
post #5 of 7 (permalink) Old 03-23-2004, 04:05 PM
If i want to a mechanic and asked for a 3.73 trak-loc pumpkin how much would b a good price for the part and labor?
JLBiRd0024 is offline
post #6 of 7 (permalink) Old 03-23-2004, 04:06 PM
Is there any way in telling if i have 3.27's or 3.08's.....cuz i dont know....i have a 95 V8 tbird
post #7 of 7 (permalink) Old 03-23-2004, 07:57 PM
JustinH's Avatar
sure, just refer to your axle code in the door jamb, and there is a decoder in the tech articles.
JH
JustinH is offline
