3.23 posi how much lower? - TCCoA Forums
post #1 of 12 (permalink) Old 03-05-2004, 09:59 AM Thread Starter
Question 3.23 posi how much lower?
Well I have factory 3.23 posi in my 97 LX. I know you can add almosty any gears but too much and you will need a computer chip to make the corrections properly. Id like to swap to 3.73 gear set or 4.11s. I am sure 4.11s I would have to get a computer and to buy the gears for 100+ dollars and a 300$ chip at the same time I don;t think I want to do. I read somewhere i thought that 3.73 gear upgrade only requires a differnet speedo gear? Or am I wrong? i plan on racing my car and just getting more performance out of it. Gears are cheap but the other expenses might add up fast. Any words of advice? 4.11s? 3.73? 3.90s? neither?
PerformanceWhite 97 Tbird LX loaded
67,000 miles
4.6 v8 with motor and exhaust upgrade
Custom Interior, Exterior and Audio
wanna be racer
1972 Cutlas Supreme 55,000 miles HO 5HIT (liscence plate)
1979 Cutlas Supreme T-top Hurst/Olds Clone, 461 Olds
Hot wheels
reckmann is offline
post #2 of 12 (permalink) Old 03-05-2004, 11:41 AM
MaleWhore
smokymance's Avatar
do they even make 3.90s or 4.11s for our 8.8 rear ends?...i thought all we could do is 3.27, 3.55, 3.73 or 4.10 for our 8.8 rear ends unless you u swap the rear axle...
smokymance is offline
post #3 of 12 (permalink) Old 03-05-2004, 01:31 PM
The Great Obucina's Avatar
3.23 is not a Ford factory ratio niether is 4.11. The EEC can compensate for a two step in gears. This has been discussed indepth...check out the search button.
3.08 - 3.55 EEC should read right
3.27 - 3.73 EEC should read right
3.08 - 3.73 EEC needs new programming
3.27 - 4.10 EEC needs new programming.
FYI, 3.23 and 4.11 are both GM ratios.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 12 (permalink) Old 03-05-2004, 02:12 PM
JustinH's Avatar
the tbird gear ratios out of the factory that I can think of are.
2.73 - fivespeed supercoupes
3.08 - most lx's
3.27 - lx option
3.31- supercoupe option automatic
JH
JustinH is offline
post #5 of 12 (permalink) Old 03-05-2004, 02:16 PM Thread Starter
Exclamation more gears
I thought I saw 3.23 ok so my rear end ration must be 3.27 posi. I know it is posi and what ic an tell by the codes. If I got to 3.73 the ECC shoul dbe OK right? I assume 4.10s would be too much without the computer to be reprogramed. thanks
Regg
67,000 miles
wanna be racer
Hot wheels
reckmann is offline
post #6 of 12 (permalink) Old 03-05-2004, 04:29 PM
one of the aftermarket companies makes 3.90 gears, can't remember the name for sure, but I think its Motive.
Chlorine is offline
post #7 of 12 (permalink) Old 03-05-2004, 05:22 PM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
3.90 gear ratio, and a whole lot more ...
Obtaining a speedometer gear that will keep eveyrthing accurate would be a challenge.
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #8 of 12 (permalink) Old 03-05-2004, 09:55 PM
Say WHAT? The ratio isn't what makes it a Ford or GM. What makes it Ford or GM, is what type of differential it's designed to bolt on to. Having many different ratios to choose from, allows racers to fine tune their cars.
Oh, & just for the record. A "Posi" (short for Positive Traction), is a GM limited slip differential. I guarantee that nobody here has a GM differential in their Ford rear end! It's a common inaccuracy, but that doesn't make it correct.
68COUGAR
68COUGAR is offline
post #9 of 12 (permalink) Old 03-06-2004, 10:51 AM
68COUGAR
niether 3.23 or 4.11 are listed as an 8.8 ratio gear offered by Ford. My friends Z28 has a 3.23 ratio from the factory and GM offers a 4.11 gear for its 8.5 diff.
joseph
post #10 of 12 (permalink) Old 03-06-2004, 10:35 PM
What's your point? Are you saying that only OEM per/year spec. are the only gear ratios that "according to YOU", are Ford?
If an aftermarket vendor makes a 3:23 gear for a Ford 8.8" rear end, is that NOT for a Ford?
There are NO Ford or GM "EXCLUSIVE" gear ratios!!!!!!!
Buy a P.A.W. or JEGS catalog, & check it out for youself!!!!
68COUGAR
68COUGAR is offline
post #11 of 12 (permalink) Old 03-07-2004, 09:51 AM
68COUGAR
or the listed available 8.8 ratios manufactured at Ford's Sterling Gear Lab offered by FRPP. I am quite aware of aftermarket manufacturer such as Motive gear who makes a 4.11 for the 8.8....BTW, F'n A....did you bother to read everything, he said he had a factory 3.23 POSI...How many posts would you like to discuss this in? His question was answered.
joseph
post #12 of 12 (permalink) Old 03-07-2004, 04:26 PM
I thought all EEC's for the Thunderbird LX automatics were programmed for 3.08 gears and they did compensate for two gear steps up. Wouldn't the 2nd gear step up really be 3.55's then? If you had factory 3.27's then wouldn't you already have used up one of your steps up? i also remember reading that if you had done the J-mod it would also help the transmission to shift "more correctly" if you do a gear change.
Correct me if i'm wrong, but i seem to remember reading this?
3.08
3.27
3.55?
Green95LX is offline
