strange question of the day, water in transmission fluid - TCCoA Forums
post #1 of 6 (permalink) Old 03-07-2004, 07:38 PM Thread Starter
JNT
JNT's Avatar
I was changing the fluid and replaceing the 1-2 accumulator with the updated version. Just before I reinstalled the pan an unexpected storm came up with strong winds and rain.
While I was reinstalling the pan water was running down from above me, past the pan as I was installing it. There might be a small amount of water that made it inside.
Should I take the time to remove the pan again and wipe out any water before adding the fluid? Should I just let it sit for awhile before adding the fluid and hope it will evaporate ?
Wishing I had a garage.
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #2 of 6 (permalink) Old 03-07-2004, 07:49 PM
You need to get that water out of there before you run it.
Water will kill the clutches quick like!
So drop that pan, you know you love Mercon V showers as much as me
billabong132132 is offline
post #3 of 6 (permalink) Old 03-07-2004, 08:10 PM Thread Starter
JNT
JNT's Avatar
How much water do you think would cause a probem?
There is probably only a few drops inside.
JNT is offline
post #4 of 6 (permalink) Old 03-07-2004, 08:15 PM
If it was my car, and there was just the possibility of water, I would dump the pan.
post #5 of 6 (permalink) Old 03-07-2004, 08:18 PM Thread Starter
JNT
JNT's Avatar
Thanks for the advice.
Not the solution I was hopeing for, but better safe than sorry.
JNT is offline
post #6 of 6 (permalink) Old 03-07-2004, 11:39 PM Thread Starter
JNT
JNT's Avatar
Well I dropped the pan and wiped it out, didn't see any water. Nothing like having to do things twice , but I feel better knowing it was clean.
JNT is offline
