98 mark tranny and speedo gears. - TCCoA Forums
post #1 of 6 (permalink) Old 03-10-2004, 03:46 PM Thread Starter
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I swapped a mark 8 tranny into my 95 lx and I used the speedo gear from the 98 tranny too. Is this correct? I have 3.08's in the 95, so what would the correct speedo gear be for the 98 output shaft?
-Thomas
Thomas is offline
post #2 of 6 (permalink) Old 03-10-2004, 04:03 PM
Silver95Bird's Avatar
Use whatever speedo gear the Tbird had in it. The Mark 8 tranny should be the same as the tbird's original tranny.
Silver95Bird is offline
post #3 of 6 (permalink) Old 03-10-2004, 04:07 PM Thread Starter
Uber Luber
Thomas's Avatar
that may explain why my odometer reads 400mi when I've gone about 300mi lol.
I thought the 98 mark's all came with 3.08 gears also?
And I also thought the output shafts were different between 95 and 98?
Thomas is offline
post #4 of 6 (permalink) Old 03-10-2004, 04:26 PM
Yep, that explains it. The output shafts are the same on Marks, but stangs got 8 tooth speedo gears while the tbirds got 7 teeth. The rear axle ratio on the mark really isnt important, if you get the output shaft and VSS teeth right the car will shift just fine.
post #5 of 6 (permalink) Old 03-10-2004, 04:41 PM Thread Starter
Uber Luber
Thomas's Avatar
I asked about the rear dif on mark's because I used the speedo gear from the 98 mark. So I need to swap in the old one from my 95 tranny? They were different colors.
-Thomas
Thomas is offline
post #6 of 6 (permalink) Old 03-10-2004, 04:50 PM
Marks have either 3.07's or 3.27's in the LSC. I don't know for sure if the Mark tranny has a 7 or 8 tooth drive gear however. My guess is that it is the same so you should use the tan driven gear if you have 3.27's. This is speculation though...
Blown306 is offline
