24k GVW Cooler - TCCoA Forums
post #1 of 29 (permalink) Old 03-11-2004, 06:39 PM Thread Starter
JoeyICU's Avatar
24k GVW Cooler
ok im going to get the search call but i need an opinion....when mounting and auxilery tranny cooler.....should one use the stock lines and mount the cooler somewere near the radiator?....or wherre the best place to mount it...i need to add one before a drag race for a day strait....i also need some input on some preventative maintence to do before one day strait of drag racing....
JoeyICU is offline
post #2 of 29 (permalink) Old 03-12-2004, 04:01 PM
MaleWhore
smokymance's Avatar
iv seen some placed on the front of the radiator...using the stock lines, just taken off the radiator an placed on the new cooler...thats what im planning on doing soon as long as someone else here proves wrong before i do...
smokymance is offline
post #3 of 29 (permalink) Old 03-13-2004, 12:02 PM Thread Starter
JoeyICU's Avatar
thats what i want to do...i dont know if that will nlower cooling capacity of the stock radiator but i figure with 22c's and a 180 stat it will probably even out
JoeyICU is offline
post #4 of 29 (permalink) Old 03-13-2004, 12:20 PM
MadRussian's Avatar
Send a message via AIM to MadRussian Send a message via MSN to MadRussian Send a message via Yahoo to MadRussian
Are you thinking of not running your stock cooler and just using an aux cooler?
-Andrey
96 LX 4.6L
13.215 @ 103.09
MadRussian is offline
post #5 of 29 (permalink) Old 03-13-2004, 01:39 PM
JustinH's Avatar
don't take the heat exchanger out of the picture, just plumb your cooler inline with it.
It serves to help warm the fluid on cold days.
JH
JustinH is offline
post #6 of 29 (permalink) Old 03-13-2004, 01:58 PM
MadRussian's Avatar
Right-o
The myth that cooler is better is not really correct. Tranny fluid should run at a certain temperature. The heat exhanger in the radiator helps it warm up because of the warm coolant.
-Andrey
96 LX 4.6L
13.215 @ 103.09
post #7 of 29 (permalink) Old 03-13-2004, 03:30 PM Thread Starter
JoeyICU's Avatar
so the heat exchanger is what the tranny hooks up to on the radiator?...how do you run line from the stock line or do you have to redo it all?
JoeyICU is offline
post #8 of 29 (permalink) Old 04-19-2004, 12:22 PM
MaleWhore
smokymance's Avatar
well i kinda designed a lil diagram...someone tellme if this is wrong or not...if so could someone edit it...
post #9 of 29 (permalink) Old 04-19-2004, 12:31 PM
JustinH's Avatar
just plumb the cooler inline with the return line (top) and you are done. No diagrams are really necessary.
JH
JustinH is offline
post #10 of 29 (permalink) Old 04-19-2004, 12:36 PM
MaleWhore
smokymance's Avatar
lol...sweet...i guess i have too much time on my hands...
post #11 of 29 (permalink) Old 04-19-2004, 02:10 PM
Holy Sh*T! This is exactly what I was looking for in my Tranny cooler trouble! Thanks a bunch man! I understand what I need to do now... You Rock!!
In case you don't read this I'm gonna PM this msg to you too! You just cleared up a bunch of mystery for me!
1997T-Bird is offline
post #12 of 29 (permalink) Old 04-19-2004, 02:14 PM
JustinH's Avatar
yeah that picture is wrong.
You want to plumb into the return line (top hardline) not the bottom line.
JH
JustinH is offline
post #13 of 29 (permalink) Old 04-19-2004, 02:24 PM
JH
The overall concept is still the same I assume, just into the top hardline instead of the bottom.
post #14 of 29 (permalink) Old 04-19-2004, 02:40 PM
MaleWhore
smokymance's Avatar
just edited the above image....and here is a repost...but as said earlier there is no need for a diagram....but here it is once more...
post #15 of 29 (permalink) Old 04-19-2004, 07:20 PM
Geek w/Gearhead Complex
Fubarian's Avatar
you could do a mount like this ...
It's a bigger cooler, but you can get the idea how it's setup. I used a couple pieces of drywall edging, drilled out two of the wholes that were already in the cooler and came up with what you see there. It's a real sturdy frame, doesn't move anywhere, no rubbing.
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #16 of 29 (permalink) Old 04-19-2004, 09:44 PM
MaleWhore
smokymance's Avatar
that looks awsome...clean setup...can i ask you where u got those lines and fittings...u got some sizes too?...that would really help...
post #17 of 29 (permalink) Old 04-19-2004, 09:51 PM
JustinH's Avatar
ask him what he paid for all those AN fittings and SS Hose.
My guess is between 150-200 bucks for the whole setup including the cooler.
Check out the prices for some of that stuff at jegs.
JH
JustinH is offline
post #18 of 29 (permalink) Old 04-19-2004, 10:03 PM
That is a very clean and very performance looking setup.
If I ever push more than 250 horses at the wheels.. I'd look into it actually!
post #19 of 29 (permalink) Old 04-20-2004, 07:35 AM
Fubarian's Avatar
it was NOT cheap as JustinH said -- and he's right, only I bought a lot of extra hose, so I dropped like 210 bucks for the whole deal (you can do it for 140 if you don't buy 20 foot of hose). I got everything at jegs and I've actually got an article up about it -- revamping it as we speak actually -- adding/moving a few things.
I used what's called AN fittings (army/navy) -- its complete overkill. The lines alone can handle up to some insane number like 1000psi @ 350' if I remember right.
Here's the other side ...I'm really happy with the mounting to tell you the truth, that's the icing on the cake. It looks good and its ROCK SOLID.
Dropped my temps to a nice 150-180 degrees.
Fubarian is offline
post #20 of 29 (permalink) Old 04-20-2004, 07:41 AM Thread Starter
JoeyICU's Avatar
im not going that sever im going to rock a 24k one and just work off the stuff they give you with the B&M cooler
JoeyICU is offline
post #21 of 29 (permalink) Old 04-20-2004, 10:07 AM
MaleWhore
smokymance's Avatar
thats what i got...i just bought mine yestarday....just got to throw it on now..i was hoping to do it today...but i got that BIG flu thats going around...GRRRRR
post #22 of 29 (permalink) Old 04-20-2004, 11:54 AM
MaleWhore
smokymance's Avatar
i just went and looked at where i shall mount the cooler and i cant figure out a way to get the tubes from the back of the radiator to the front...any ideas?
post #23 of 29 (permalink) Old 04-20-2004, 02:35 PM
I can tell you this, if you choose to mount it under the power steering cooler.. The splash sheild will have to go... It's really hard to get off and it's very frusterating !
Where are you mounting it anyway?
post #24 of 29 (permalink) Old 04-20-2004, 03:35 PM
MaleWhore
smokymance's Avatar
i dont know
i know that i have to buy new fittings...they are a lil too big...so i have to get a downsizer for the fittings it came with
post #25 of 29 (permalink) Old 04-25-2004, 09:48 PM
jturmel's Avatar
...or you can do it like this, and go with even larger lines and all hardlines.
Dual 28,000 B&M's and upgraded to all 3/8" hardline to and from transmission and coolers.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #26 of 29 (permalink) Old 04-26-2004, 11:57 AM
Fry Rice Specialist
Casper's Avatar
did you customade the hardline your self?
more info on this please?
CarDomain Page
Casper is offline
post #27 of 29 (permalink) Old 04-26-2004, 10:02 PM
jturmel's Avatar
Yup.
3/8" hardline from local parts store, hand bent with pipe bender. Lots of time + some money = nice setup.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #28 of 29 (permalink) Old 04-27-2004, 07:47 AM Thread Starter
JoeyICU's Avatar
so where did you mount them to baddies?....thats sounding like a good summer project...rocking two coolers...maybe smaller then 28k GVW ones like twin 18k ones for me
JoeyICU is offline
post #29 of 29 (permalink) Old 04-27-2004, 10:53 AM
Fry Rice Specialist
Casper's Avatar
with twin coolers is there any risk of losing pressure? or the pump overwork?
CarDomain Page
Casper is offline
