Question for people that have installed dif gears - TCCoA Forums
post #1 of 41 (permalink) Old 03-12-2004, 01:57 PM Thread Starter
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
I've been trying to decide whether I want to buy the pumpkin from Justin or install my own gears. I'd have to install the trac-loc and the new gears and have been reading up on it. I know that If I had to purchase everything new than I'd be way better off getting the pumpkin, but lets say I could get the trac-loc and gears for a couple hundred and install everything myself, I stand to save at least $100 when finished which is enough to motivate me to do it myself, I've had some experience in a rear end(no pun intended) and from what I have read it seems like the hardest part about doing this is setting the pinion depth. What I want to know is for those that have done this is it has difficult as it sounds?
"Technical skill is mastery of complexity while creativity is mastery of simplicity."
94t-birdlx is offline
post #2 of 41 (permalink) Old 03-12-2004, 02:14 PM
I would highly recommend getting the pumpkin if you've never set up gears before.
It is very easy to ruin a set of perfectly good gears if they aren't setup correctly.
There are a lot of things involved such as setting the contact pattern, backlash, preload on the bearings, etc... It's not just a matter of setting them in there and bolting them up. The guy who sets up my differentials usually does it about 3 times each to get it perfect. (But he's doing this for professional NHRA racing, so everything has to be perfect)
And if you don't do it yourself, then you'll be paying someone to set it up ($200) and you have to trust them to do it right.
Just my .02.
69 F100 LWB w/460 Engine
post #3 of 41 (permalink) Old 03-12-2004, 02:32 PM Thread Starter
94t-birdlx's Avatar
Well I've been reading up on it and it looks very involved. My initial plan was to get the pumpkin but a friend of mine says that the gears would be easy enough to do myself, he has set them up in some trucks that he has had, and so I thought I'd look into it. I've seen write-ups that make it seem like its impossible to do for the home mechanic, all the way to write-ups that say its a piece-o-cake. I was hoping to hear some of the experiences here. Some people(including some manuf.) say that the contact pattern is the final judge of the setup. I would like to have the privilage to just bolt up a new carrier but I would also like to get the experience of the total rebuild.
Adam
post #4 of 41 (permalink) Old 03-15-2004, 02:58 PM
I'm a "Gear-Head" from WAY back, & I won't even attempt a ring/pinion setup. Pay a pro once, or buy all the parts AGAIN when it fails, & still end up paying the pro!!!!!
68COUGAR
68COUGAR is offline
post #5 of 41 (permalink) Old 03-15-2004, 03:01 PM
JustinH's Avatar
I have five units left for sale.
JH
JustinH is offline
post #6 of 41 (permalink) Old 03-15-2004, 11:13 PM
If you're going to go with 3.73 gears, just get the FRPP pumpkin and be done with it. There is no better deal available, and you won't save an money buying the individual pieces to assemble yourself.
Decy is offline
post #7 of 41 (permalink) Old 03-15-2004, 11:38 PM
JH
what's the shipped price?
86TCboy is offline
post #8 of 41 (permalink) Old 03-16-2004, 06:06 AM
JustinH's Avatar
JustinH is offline
post #9 of 41 (permalink) Old 03-16-2004, 02:03 PM
Aaron_T's Avatar
Setting up the ring and pinion is not "that" hard, it just takes time, and the appropriate tools. My 4.10's make no noise what so ever, and have been flawless since we put them in. The guy I bought them from had only setup a couple sets before mine (maybe only one), but he had guides for when he did his on his Capri. He also had all the right tools plus he is very mechanically inclined, which I think I am pretty mechanically inclined myself. He wouldn't take any money for helping me neither. With the like-new Ford Racing gears from him plus the seals it was a $130 mod (I already had limited slip).
Since you don't already have limited slip (I assume since you said you need to install it), and you want 3.73's, then I would say the pumkin from Justin would be the best deal for you.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #10 of 41 (permalink) Old 03-16-2004, 04:33 PM Thread Starter
94t-birdlx's Avatar
Yeah, all I have right now is 3.08 open. I was trying to save some money on the gears so the gear/chip mod wouldn't hit my pocket so hard. I've seen some on ebay with a trac-loc for about $200 and with my friend telling me it would be easy I figured I'd take a look and see what it would take. Looks like I'll be sittin on it for a while.
Adam
post #11 of 41 (permalink) Old 03-17-2004, 12:57 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
I agree in saying that gears are actually quite easy when you know what you're doing. I spent a grand total of about $320 to buy brand new gears, new bearings, new clutchs, all that jazz. The install cost me a case of Bud Light. And this is a guy who's recommended the highest by everyone in this 150,000 population area. As he showed me and taught me how to install, its a matter of having access to the proper tools and taking your time. Mine haven't made a single peep since the new clutches stopped chattering. Mine were set up with a .006" backlash (recommended range is .008"-.015") and they don't make any noise at all. Check the wear pattern a few times before you call the job done, than break them in proper and you'll never have a problem.
Ask around the local hot rodders, and see who's good at setting up gears. Then talk to them about a price to do the job, you might be able to find someone like me who'll do it for beer as long as you do the nasty work (cleaning everything).
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #12 of 41 (permalink) Old 03-17-2004, 07:14 AM Thread Starter
94t-birdlx's Avatar
About how long did it take you do do the swap? I figured like a weekend would be long enough to drop the pumpkin, do the swap and put it back together. I've seen the pinion depth tool for about $100-$150. I figured that plus maybe $300 for the gears/trac-loc would run me under $500 for the gears and then I could put the extra towards the chip. I'm gonna continue to read up on it. Thanks for all the input too!
Adam
post #13 of 41 (permalink) Old 03-17-2004, 10:27 AM
Sheepish
AverageJoe's Avatar
You don't need a pinion depth tool, just a dial indicator for checking the backlash. When we did mine we started with the biggest shim available for the pinion gear (.030") and were prepared to go smaller if necessary. We bolted it all together and checked the backlash, aweful tight, but the installer said that was fine. Brushed gear checking compound onto the ring gear and ran it around a few times, the wear pattern came out perfect so we got kinda lucky there.
Also, I spent about 2 hours dropping my pumpkin the first time, did it with zero help and zero power tools. The swap took about 4 hours since I was slow, and then spent about 1.5 hours putting it back in. Easily done in a saturday, let alone a whole weekend.
post #14 of 41 (permalink) Old 03-17-2004, 10:47 AM Thread Starter
94t-birdlx's Avatar
So you basically went by the backlash and wear patter for the measurement? I think that this wouldn't be too hard to do but the thing that gets me is it seems like you don't really know if you did a good job untill its too late. I guess I'll check around for dial indicators. I think that I might try and tackle this! Thanks for the the different opinions.
Adam
post #15 of 41 (permalink) Old 03-17-2004, 11:08 AM
Sheepish
AverageJoe's Avatar
Like I say, you check the wear pattern VERY VERY closely and that'll let you know of the pinion depth is acceptable. Its your choice wether or not to do it with a pinion depth tool, but one thing thats a must is a bad *** impact. Otherwise you'll never get the new pinion nut and crush washer on.
post #16 of 41 (permalink) Old 03-17-2004, 11:20 AM Thread Starter
94t-birdlx's Avatar
I have a decent impact and I'm sure if I needed more I could borrow one of the big ones from my buddies work. He's got the big indutrial ones to take lugnuts off mack trucks. Those things are nuts!
post #17 of 41 (permalink) Old 03-17-2004, 12:54 PM
Aaron_T's Avatar
If you don't have access to a lift, removing the pumpkin would make it a lot easier.
I would say if you wanted to attempt it, go for. Just take your time, and "good enough" probably means wrong in this case. You need everything almost perfect.
You could either get a barebones install kit (Summit sell them), or just get the separate parts locally. Shims are important, so you will probably want new ones incase you need to add any to have it setup right. I actually didn't need to add any to mine, but not every setup is gonna be the same.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #18 of 41 (permalink) Old 03-17-2004, 01:36 PM Thread Starter
94t-birdlx's Avatar
Does this mean it could be done while the pumpkin is still in the car? My buddy said that it could be but I didn't think it would be too easy that way. He says its easy and I'm convinced that its a lot harder. I don't have a lift but could get it up in the air pretty good.
post #19 of 41 (permalink) Old 03-17-2004, 03:07 PM
Aaron_T's Avatar
It could be done, but I think it would just be a big PITA. It doesn't take much to get the whole pumpkin off of the car, then you could just use a work bench or whatever for setting them up and cleaning everything out (we were able to get mine spotless o the inside). Also I think you would be hard pressed to get an impact wrench powerful enough to crush that crush collar, except maybe that one for mack trucks. You need a lot of force to get it to crush all the way, which if you use a ratchet/socket, you need a pry bar for sure, and underneath the car there isn't much room to move one around.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #20 of 41 (permalink) Old 03-17-2004, 03:16 PM Thread Starter
94t-birdlx's Avatar
I'll probably pull it out just to make sure that I get it right, The actuall pumpkin drop is a piece-o-cake. I'd rather do the fun stuff in the garage!
Adam
post #21 of 41 (permalink) Old 03-17-2004, 03:20 PM
Aaron_T's Avatar
Yeah it was actually pretty fun/cool to help with since I had always been told how "difficult" it was to set them up right. Plus learning something new about cars is nice. Good luck with it, and keep us posted
Check this thread out -
http://forums.tccoa.com/showthread.p...h+collar<br />
Most of what has been said in this thread is in there, but there's a link to a guide....
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #22 of 41 (permalink) Old 03-17-2004, 03:33 PM Thread Starter
94t-birdlx's Avatar
Correct me if I'm wrong but an 8.8 28 spline trac-loc will fit correct?
post #23 of 41 (permalink) Old 03-17-2004, 06:29 PM
Depends on what YOU mean by "fit"!!!!!
(1) You CAN'T put an 8.8" differential in a 7.5" housing.
(2) You CAN replace your 7.5" pig with an 8.8" pig without problems.
(3) You want an IRS 8.8" differential.
(4) You do NOT want a Solid Axle 8.8" differential.
If you decide to replace your pig, you may want to think about replacing the front diff. mount bushings at the same time. You can use OEM Ford rubber bushings, Poly bushings (which are GREAT!!!!), or aluminum ones.
68COUGAR
68COUGAR is offline
post #24 of 41 (permalink) Old 03-17-2004, 08:46 PM
Aaron_T's Avatar
Wouldn't he already have an 8.8" rear end - 94' 4.6L
I assume 3.08 gears since he doesn't have LS already.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #25 of 41 (permalink) Old 03-17-2004, 09:40 PM
toofast4u's Avatar
Send a message via Yahoo to toofast4u
There is a guy I know that sells new FFRP punkins with 3:73s for $500 plus like $25 shipping.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #26 of 41 (permalink) Old 03-17-2004, 10:05 PM Thread Starter
94t-birdlx's Avatar
I have the 3.08 right now and I was under the impression that they were 8.8 housing.
post #27 of 41 (permalink) Old 03-17-2004, 11:16 PM
Aaron_T's Avatar
That's what I thought, people need to stop confusing me lol. There should be a metal "tag" on your diff. cover that will tell you. It should say somewhere on there 3.08 8.8
3.08 open is what I have in my 95'
I just thought about something, do you have traction assist?
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #28 of 41 (permalink) Old 03-17-2004, 11:35 PM
Sheepish
AverageJoe's Avatar
Look at your driver's doorjamb and see what it says under the AX code and then check the Gears tech article on this site. If your car came with a V8, its got the 8.8, no questions asked.
Anyways, you CAN use a live axle 8.8 carrier in your IRS, but its not recommended. The IRS units have a groove on the inside of the splined area of the side spider gears to accept a circlip on the half shaft stub. If you remove said circlip, the halfshafts will slide into a live axle carrier just fine, and be retained by the IRS knuckles, they won't allow the halfshafts to go anywhere, but they will allow some in/out play. The circlip grooves in the IRS side gears are there for that reason.
When i was under mine, there's no room to remove the carrier from the housing without hitting the rear of the IRS subframe so I don't think its possible to do the gears with the pumpkin in the car. Just drop it out and do the gears on a bench.
Aaron T should be able to agree with me that gears are actually a whole lot easier to do than they're made out to be, but they're so labor intensive due to shimming and whatnot. I HIGHLY recommend the FRPP gears because they'll require the least effort of all to put in.
post #29 of 41 (permalink) Old 03-18-2004, 05:52 AM
Aaron_T's Avatar
Yeah they are definitely a lot easier than people make them out to be.
Just don't rush and you should be fine
Average Joe is also right about te FRPP gears. You won't have to worry about them fitting correctly or not (like an OEM fit), and they are superb quality.
Used gears aren't normally recommended, but you may be able to find a ring & pinion set that's in like new condition on Ebay or somewhere else. It just kind of depends on how well they were setup originally, how many miles etc.... The 3.27's in my 97' had around 55,000 miles on them and they were in really good condition. You would just have to be real careful with what you find if you go that route.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #30 of 41 (permalink) Old 03-18-2004, 06:17 AM
Sheepish
AverageJoe's Avatar
Also a tip for getting the pinion depth right. Start it with the thickest shim (.030") and work your way down. We didn't have to shim my carrier for the backlash and the .030" shim between the pinion teeth and the first bearing got my wear pattern dead on. I don't know if you'd be that lucky. My backlash came to .006" which is .002" below the recommended minimum, but I haven't had any problems yet with the gears, no noises whatsoever, and the pro who did mine said that backlash is perfectly fine as long as the wear pattern comes out proper and you break the gears in proper.
