My shifter - TCCoA Forums
post #1 of 6 (permalink) Old 03-13-2004, 08:26 PM Thread Starter
My shifter
last night..my sunroof quit working...then earlier...i start the car..and i go to put it in gear..and the button on the shifter wont move..i have the brake in and everything..but nothing happens..what is goin on here?
Andrew-L is offline
post #2 of 6 (permalink) Old 03-13-2004, 10:07 PM Thread Starter
anybody? this is a daily driver and i need a fix soon
Andrew-L is offline
post #3 of 6 (permalink) Old 03-14-2004, 05:22 AM
you can bypass the Shift Park Interlock? thing this way. Put your finger on the button, and try to push it in, then turn the key slowly towards the "ON" position until the button goes in, now you can slide the shifter back a hair and start the car. Do you brake lights work? Check the the brake light switch if they don't, also you might check fuses since the sunroof also quit.
Green95LX is offline
post #4 of 6 (permalink) Old 03-14-2004, 12:15 PM
3rd Gear Chirper
hotbird's Avatar
Check ALL your fuses, and by check, I mean take each one out and inspect it in good lighting. Don't forget the fuses in the engine bay either. And yeah, Green95LX is right, just turn the key one position forward from LOCK and press the button. (Or just disconnect the cable like me)
hotbird is offline
post #5 of 6 (permalink) Old 03-15-2004, 12:06 PM Thread Starter
..it was a blown fuse..my seats werent working either! i didnt know a fuse could do all that damage..no shift..no brake lights..no sunroof..no electronic seat controls
Andrew-L is offline
post #6 of 6 (permalink) Old 03-15-2004, 12:42 PM
Well see, the brake light switch also tells the shift lock that you have the brake pedal depressed. So when the brake pedal switch doesn't get power or fails, the shift interlock won't function also.
