tcc replacement - TCCoA Forums
post #1 of 21 (permalink) Old 03-14-2004, 06:43 PM Thread Starter
02 Explorer Pioneer
timb's Avatar
tcc replacement
Anyone who has had to replace their tcc solonoid what were the symptoms? I think this is my issue. After the car is warmed up (15 minutes driving) when pulling up to a light the engine will drag down below 500 RPM and stall unless I give it a little gas or pop it in neutral. I am fairly certain the tcc is partially locked when this happens but I was wondering if the tcc solonoid can partially fail like this or is it all or nothing? The only other thing that could be happening that I can think of is that the seals around the plunger have gone bad and it's not fully depressing the shaft. Is there a definitve way to test either scenario?
Birdless
timb is offline
post #2 of 21 (permalink) Old 03-14-2004, 06:45 PM
JustinH's Avatar
is this the original trans Tim?
My 95 would stall at redlights after long highway runs, it turned out to be the TCC Solinoid.
You had to give it a little gas to keep it from stalling.
JH
JustinH is offline
post #3 of 21 (permalink) Old 03-14-2004, 06:52 PM Thread Starter
02 Explorer Pioneer
timb's Avatar
Yep origional trans 235K
I guess I go pick up a solonoid tomorrow and prepare for a mercon shampoo
Thanks for the response...sounds like the same thing
Birdless
timb is offline
post #4 of 21 (permalink) Old 03-18-2004, 08:08 PM
Actually I had the same symptoms. I thought it was the TCC solenoid too, but it turned out to be the Idle Air Control. One way to differentiate is put the car in Park and turn on your AC. If you idle starts to oscillate up and down, it's probably your IAC. I would check the IAC first and clean it out (I used Oxygen sensor safe Gum-out). I found a lot of carbon deposits in there. After cleaning and reinstalling, no more stalling and no more idle fluctuations while the AC is on. Hopefully this is helpful for you. Good luck.
-Leo
leojeng is offline
post #5 of 21 (permalink) Old 03-20-2004, 08:25 PM Thread Starter
02 Explorer Pioneer
timb's Avatar
Just a follow up the new tcc solonoid did the trick
Birdless
timb is offline
post #6 of 21 (permalink) Old 03-23-2004, 02:50 PM
For all of about 50 miles...
Sorry, could not resist!
Cam94 is offline
post #7 of 21 (permalink) Old 03-23-2004, 02:58 PM Thread Starter
02 Explorer Pioneer
timb's Avatar
Hahahahahaha
Actually it doesn't look like the trans was the issue....I wouldn't dare try to use it anymore but it looks like the coverter balooned and bits of it broke apart inside and the housing cracked. There is a nice stream of Merc V coming out the bellhousing drain hole
Birdless
timb is offline
post #8 of 21 (permalink) Old 03-23-2004, 03:01 PM
Better tell Andrea to put the bucket under her when she arrives home otherwise you will have the Mercon pool in the driveway after all!
Cam94 is offline
post #9 of 21 (permalink) Old 07-01-2004, 06:18 PM
I have the same problem... still I replaced the TCC solenoid... no change.. I noticed it from the way home from Doing the J-Mod a while ago my O/D light started flashing... If I put it in 2nd and a stop and hit the gas the car will usually stall
So it looks like the TCC "solenoid" is electrically stuck on... not mechanically right..?
Anyone have this problem and the solenoid didn't fix it?
I don't really wanan mess up the car to much.. and I wanna put a 2500 stall TQ in it and I would like to have this problem fixed before I do that..
any help would be great...
SkunkWorks is offline
post #10 of 21 (permalink) Old 07-06-2004, 05:52 PM
ttt
post #11 of 21 (permalink) Old 07-06-2004, 07:25 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
where are you guys getting these TCC Solenoids?
My dealer here in town wants 120 bucks!!
napa can get me one... but they say its will work for 94 THROUGH 98...
which I know to be wrong, because the 94-95's were different than the others. (lower ohm's or something)
thanks guys
MG
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #12 of 21 (permalink) Old 07-06-2004, 07:30 PM
120? there like 20 bucks or something...
post #13 of 21 (permalink) Old 07-06-2004, 10:11 PM
Lazania's Avatar
I had this happen before too and it was the Torq conv as well
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #14 of 21 (permalink) Old 07-06-2004, 11:40 PM
why would be be the TQ? how...? I'm going to put a new one in anyways.. I wanted to fix the problem before I did... btut if it was a TQ problem then would be cool. but I doubt it is/was/could be
post #15 of 21 (permalink) Old 07-07-2004, 12:19 AM
MaleWhore
smokymance's Avatar
sorry to maybe get this out of the topic, but what are some sypmtoms of a bad Throttle position sensor?
smokymance is offline
post #16 of 21 (permalink) Old 07-07-2004, 12:59 AM
Silver95Bird's Avatar
I got a TCC shipped to my door from Dan Newman for ~$24. For that kind of cash I'd buy it from him and then see where it goes, especially if it appears the TCC has failed.
Silver95Bird is offline
post #17 of 21 (permalink) Old 07-07-2004, 08:42 AM
Lazania's Avatar
Usually your car will idle up and down trying to find a idle becuase the TPS is stripped inside and its not staying @ .99 volts @ idle. You could test it with a Multimeter use the mV setting. Usually thats what they do when they go bad. Good Luck
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #18 of 21 (permalink) Old 07-07-2004, 11:54 AM
MadGoat's Avatar
thats exactly what mine did
mg
MadGoat's Birds
RIP
MadGoat is offline
post #19 of 21 (permalink) Old 07-08-2004, 11:24 PM
Put the car in manual 2nd. If the TCC solenoid is stuck, or if its driver in the PCM is shorted or the wiring is shorted to ground, the tranny will try to stall the engine.
A little electrical sleuthing will save a lot of time and $.
bill_s is offline
post #20 of 21 (permalink) Old 07-09-2004, 12:00 AM
MadGoat's Avatar
interesting... mine does this on occsaion...
just another problem this 94 peice of $#^% has ...
and more reason to get a new TCC for the new tranny rather than swapping the old into the new.
MG
MadGoat's Birds
RIP
MadGoat is offline
post #21 of 21 (permalink) Old 07-09-2004, 01:15 AM
I have this problem.. seemed to turn up after I did my jmod... I replaced the tcc solenoid already and it didnt solve it.
What else should I look at..?? Driver in the PCM..? and check the wire harness that the TCC plugs into...?
Any idea if having the TCC lockup in 2nd and what not at low rpms can hurt or burn anything out?
Thanks...
-Cam
