marauder TC - TCCoA Forums
post #1 of 14 (permalink) Old 03-14-2004, 08:24 PM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
marauder TC
ok, DvlBrd is droppin a mar. TC into his bird, the flywheel won't match up -- any ideas as to whats going on and why it won't match up? (sorry, he's kinda tied up at the moment)
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #2 of 14 (permalink) Old 03-14-2004, 08:35 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Is he using the Mark VIII flexplate? Will it not match up to the TC or to the back of the crank? I didnt think my Mark VIII flexplate was going to bolt up to the back of my crank, 3 of the holes would line up while the other 3 were just a little off. I had to rotate the flexplate around one hole at a time until thay all matched up. I guess it has its own "bolt pattern"
Sold = 96 Thunderbird
Aaron K. is offline
post #3 of 14 (permalink) Old 03-14-2004, 08:51 PM
Chapter Director Coordinator
jamesD's Avatar
Dennis mentioned something about a flexplate....
maybe call him tomorrow morning and ask??
jamesD is offline
post #4 of 14 (permalink) Old 03-14-2004, 09:13 PM Thread Starter
Fubarian's Avatar
na, the bolts line up to the crank just fine, its the bolts of the TC -- he thinks the flywheels are all the same (all thunderbird flys) and not a mark8
Fubarian is offline
post #5 of 14 (permalink) Old 03-14-2004, 09:49 PM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
These are crappy (webcam) pictures of the offending flywheel/flexplates. I think they are the same damn ones. I was supposed to get a Mk8 flywheel ...
The T-bird one is clearly marked (one on the right):
Individual shot of my 'bird flexplate:
Here is what I am calling the "mystery plate" until it is ID'ed. It matches up exactly with my stock one, except for the fact there are only two ... holes ... rather than three (compare both pics and you will see what I am talking about):
For fun, here is the Marauder torque converter:
Here is my problem: BOTH flywheels will attach to the stock one and the Mark8 converter that is sitting outside (at least, I was told it was a Mark8 converter), but neither will attach to the Marauder one.
This sucks.
Also, thanks Jesse for starting the thread based upon my pissed off phone call to you. I know you have nothing to do with this, but you have always been a good friend that listens when I complain or $#%*& about something.
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #6 of 14 (permalink) Old 03-14-2004, 09:56 PM
fast Ed's Avatar
Are there any I.D. numbers on the flexplate that is supposed to be from a Mark VIII? The service part number is F3LY-6375-A, so the stamping number on an original part should start with F3LE or something similar ... F3L means 93 Mark VIII.
If you find a number on it, post it here, I'll try to tell you what you have if I can.
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #7 of 14 (permalink) Old 03-14-2004, 09:58 PM
66dvlbrd68's Avatar
cheers,
Ed Nicholson
SCCoO
I am going to go back outside and see what I can find. We're packing up for the night. I'm going to take EVERYTHING to ford with me tomorrow and find a damn flywheel that will work.
If I find a part number, I'll post up. Thank you Ed for always tryin' to help.
post #8 of 14 (permalink) Old 03-14-2004, 10:03 PM
Aaron K.'s Avatar
I dont think that Mark 8 TC that you have is a Mark 8 TC if your stock flexplate fits it. I think you have two stock flexplates and two stock converters. Does the TC you think is the Mark 8 look any smaller than your stock TC? Is it the same size as the Marauder TC? I would take the TC you think is the Mark 8 and try to match it stud to stud with the Marauder TC.
Aaron K. is offline
post #9 of 14 (permalink) Old 03-14-2004, 10:15 PM
66dvlbrd68's Avatar
Aaron and James, thanks for your replies ...
Aaron, I put them on top of each other and both my stock (dead) converter and the "used Mark 8" converter are THE SAME SIZE. The only difference is that the "Mk8" one does not have a drain plug ...
The Marauder one is substantially smaller ...
post #10 of 14 (permalink) Old 03-15-2004, 07:51 AM
JoeyICU's Avatar
well im the reason why he has what he has...i dont know how he got a tbird TC and flywheel but id guess my....i dare say this...friend...has something to do with the diff tc and flywheel going on...im going to find out today....ill check my garage to make sure i dont have a flywheel from a gt mustang just siting around....but my tranny....had....a gt TC on it and a gt flywheel...so i will find out and get back to on ya it and all but im seriously pissed....i guess the use of my garage by certain people will stop
JoeyICU is offline
post #11 of 14 (permalink) Old 03-15-2004, 11:01 AM
Refrigerator Raider Hater
GreenBird's Avatar
The mark8 and mara TCs are the same size. I think he was right when he said you have 2 stock flexplates and two stock TCs.
My mark8 flexplate bolts upto my mara TC just fine.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #12 of 14 (permalink) Old 03-15-2004, 11:08 AM
Aaron K.'s Avatar
Mike and Matt, do your Marauder TCs have drain plugs? I dont think any of the Marauder TCs have them but I'm just curious.
Aaron K. is offline
post #13 of 14 (permalink) Old 03-15-2004, 11:21 AM
66dvlbrd68's Avatar
No drain plug on mine. I think GB (Matt) and everyone else is correct. I have two stock converters. I am going to get on the horn with Dan Newman as I type this and order a Mk8 flexplate. Not one single place in town has one. Hell, the SVT dealer in town ... the guy said the part number was not in the computer and that he "doesn't know anything about Lincoln Mark 8 flexpltes working on a Mustang, or vice versa."
So, I give up. I am ordering the flex plate and going to have the car towed to a transmisison place and have them install it. Logistics of getting help from people and random BS like parts breaking (bolts, etc.) or parts not working have hampered this project from the beginning. I need my car to get around (only vehicle I have) ... so it looks like my "save $$$ by doing it yourself" has turned into a 4 month expensive layoff.
*sigh*
I am going to go bang my head on a wall for a while ...
post #14 of 14 (permalink) Old 03-15-2004, 11:52 AM
fast Ed's Avatar
Make sure you get the correct hardware if you don't already have it ...
F1AZ 6379 A is the number for the bolts for the flexplate to the crank, they come in a package of 6, the proper amount, about $2.00 each. And F6AZ 6441 AA, package of 4 at about $1.50 each, are the flexplate to converter nuts.
Good luck with it,
cheers,
Ed N.
fast Ed is offline
