Mark 8: Drive Shaft Question - TCCoA Forums
post #1 of 3 (permalink) Old 03-16-2004, 02:43 PM Thread Starter
Roy Batty's Avatar
I have a 91 3.8L with blown hg's. Soon i will be swapping out the 3.8L for a HO. Now i read somewhere that the Mark 8 driveshaft will not work with a 3.8L. How can I make this work for for the HO?
Everyday of my life is a constant fight, between wrong and right.
When there is no grass on the field, go around back and play in the mud.
Roy Batty is offline
post #2 of 3 (permalink) Old 03-16-2004, 07:32 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
whats your reason for getting a mk8 DS? if its for weight reduction, theres not much difference in the mk8 and AOD DS as far as weight goes. you are better off using your stock DS.
where did you read that the mk8 DS wont fit? someone around here with a 3.8 did this DS swap (jim i think?).
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 3 (permalink) Old 03-16-2004, 09:48 PM
Jim did get one in, barely with his 7.5 rear end. RancherLee couldn't get one of Dennis Reinhart's DS in his car last year and his has an 8.8. The 4.6 DS is about an inch longer than the 3.8 DS.
