Tranny dead? options? - TCCoA Forums
post #1 of 6 (permalink) Old 03-21-2004, 05:49 AM Thread Starter
Well today, my OD went out.
I was on my way home, it was windy, I pushed the gas a little harder to get up to speed, slipped a little bit to get there, like a bad clutch in a manual, and then it caught and went.
I set the criuse, and then, a gust of wind came up, car went to accelerate, and then the tach rose, speed fell, turned off cruise, nothing, it would not catch.
I put the car into D and drove it like that.
Stopped off on the way home, came back a few hours later, and when I left(car was cold as ice). I went to leave, had it in d, car went, shift from first to 2nd, no third, until I railed on it and got the speed up there, then I got 3rd.
The tranny doesn't have 125k on it yet. It got regular flushes/filter changes, I checked the fliud, it is still pretty clean yet.
I don;t know much about trannies, but, I may be able to get a diff one for 250$.
Would this be an easy fix on this tranny? like something simple or?
Thanks!
sc0tty8 is offline
post #2 of 6 (permalink) Old 03-21-2004, 10:03 AM
Silver95Bird's Avatar
sounds like both the od band and the direct clutch are done. No choice but to rebuild it.
Silver95Bird is offline
post #3 of 6 (permalink) Old 03-22-2004, 11:01 AM Thread Starter
How hard is it to rebuild one of these units? Cost?
I found a used one for 200$.
I should replace the tc while I am in there. Any good ones I should look at? I plane to add in a trickflow cam down the road.
sc0tty8 is offline
post #4 of 6 (permalink) Old 03-22-2004, 04:56 PM
$200 is cheaper than the rebuild, but a proper rebuild will last longer. It depends on your intentions for the car...
post #5 of 6 (permalink) Old 03-23-2004, 12:04 AM Thread Starter
I am hoping to take the old one and rebuild it. I see ford racing has some wide gears for it, I am thinking thats what I will put in it, to get my heavy car moving
sc0tty8 is offline
post #6 of 6 (permalink) Old 03-23-2004, 02:58 PM
Read the OD 101 article fully before you start buying parts - you might learn a few things...
