Are these the right updated accumulators? - TCCoA Forums
post #1 of 7 (permalink) Old 03-24-2004, 09:08 AM Thread Starter
toofast4u's Avatar
Send a message via Yahoo to toofast4u
Ok I got the today 1-2 is part # f7az-7f251-aa I'am sure this is the right one but the 2-3 accumulator i got is part # f7az-7h292-ab and it's made of plastic is this the right one? I thought the 2-3 was metal not plastic thanks.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #2 of 7 (permalink) Old 03-24-2004, 09:15 AM Thread Starter
toofast4u's Avatar
The part # on the box is f7az-7h292-ab and the part # on the accumulator is eoap-7f251-ab
post #3 of 7 (permalink) Old 03-25-2004, 09:04 PM Thread Starter
toofast4u's Avatar
Well I ordered one more today same thing damm plastic part in the wroung box I guess it's time to give up on my local dealer and call Dan.
post #4 of 7 (permalink) Old 03-25-2004, 09:20 PM
Check the picture in this thread. It shows the 2-3 piston, is the one you have? The number on the piston is a casting number, not the actual part number.
post #5 of 7 (permalink) Old 03-26-2004, 07:45 AM Thread Starter
toofast4u's Avatar
No it's a white plastic piece and it has 2 o rings on it one on the top and one one the bottom.
post #6 of 7 (permalink) Old 04-22-2004, 11:18 PM
ITT-BIRD's Avatar
WELL WELL WELL ... i went to get my accumulator and spring today but teh part numbers didnt match ... i printed the parts list and it has ****-*****-ba
whats the right spring #
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #7 of 7 (permalink) Old 04-23-2004, 09:24 PM Thread Starter
toofast4u's Avatar
I got so mad at the stealership they ordered the wroung part 3 times!! I ordered them from dan I got the right parts and they where cheaper 2!
