j-mod/help.. 2-3 accumulator won't fit - TCCoA Forums
post #1 of 9 (permalink) Old 03-24-2004, 03:00 PM Thread Starter
Unhappy j-mod/help.. 2-3 accumulator won't fit
I can't get the 2-3 accumulator piston in. I've saturated it in atf and it still won't go up in. I've even taken an 18mm socket with extension and tried to force it in. Has anyone else had this problem? The bottom lip of the piston will go as far up as the surface with where the valvebody bolts up to. I've triple checked the part # with max and it's right. So i'm clueless at this point. PLEASE HELP
Adam B. is offline
post #2 of 9 (permalink) Old 03-24-2004, 03:22 PM
I thought the same thing when I did mine last week. I ended up just getting it in there far enough so that the cover with the 3 tabs on it would hold it in, and would still allow the valve body to be bolted up. Mine shifts fine, so I assume that this is correct. Not a tranny expert, but I'm sure that if the way I did it was wrong, that the 2-3 shift would be acting funny, or not doing anything at all. I'm sure someone w/ more knowledge will comment.
FordMan77 is offline
post #3 of 9 (permalink) Old 03-24-2004, 03:29 PM Thread Starter
See, I can't even get the retainer up into the bore(with piston in). The clips don't even touch it?
Adam B. is offline
post #4 of 9 (permalink) Old 03-24-2004, 03:43 PM
You did take the other piston out right?? Just making sure because it sounds like something is stuck in there
MattsLE97 is offline
post #5 of 9 (permalink) Old 03-24-2004, 03:51 PM Thread Starter
Yup, just a bare bore. Do you think that it could be a bad piston. It looks fine, perfectly round, nothing torn, etc. I have blisters on my hand from trying to get it up in there
Adam B. is offline
post #6 of 9 (permalink) Old 03-24-2004, 03:55 PM
02 Explorer Pioneer
timb's Avatar
If the top part of the piston is not exactly aligned it will apear that the bottom is stuck. Try moving it around trying to seat the top and the rest will follow
Birdless
timb is offline
post #7 of 9 (permalink) Old 03-24-2004, 04:01 PM Thread Starter
Never mind...I'm retarted You were right the other piston was still in there. Lack of light anyways thanks for putting up with my ignorance.
Adam B. is offline
post #8 of 9 (permalink) Old 03-24-2004, 04:53 PM
No you're not, just inexperienced. don't feel to bad, I alost did that on the 1-2, lol! Granted I had been up for 13 hours by then so my mind was a little tired. Glad to hear you figured it out. Now go get that car done!! You won't regret it.
post #9 of 9 (permalink) Old 03-24-2004, 06:06 PM
glad to hear you got i figured there had to be something stuck/still in there. I had a little problem with my 1-2 just a little patience and it worked
