New Dennis R tranny, I have a leak? - TCCoA Forums
post #1 of 4 (permalink) Old 03-29-2004, 09:09 AM Thread Starter
The tranny makes the car a whole 3 sec faster on the 0-60. So I am very happy with it. But it leaks every time I drive it. About a spot the size of a hand ball. But only if the car has a chance to warm up. Never when I just cycle through the gears sitting in my drive way. I check the tranny leval and keep it full. So mechanical failure isn't to likely. But that damn fluid makes a mess and it isn't cheap for MER V. Does any one know what seals or "o" rings need to be new when performing a tranny swap? Or what has leaked when doing the same swap? Thanks...Eric
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #2 of 4 (permalink) Old 03-29-2004, 10:46 AM
95BLKLSC's Avatar
wow 3 second faster on 0-60? how bad was yoru trannie before??
My Car Domain Page
95BLKLSC is offline
post #3 of 4 (permalink) Old 03-29-2004, 04:38 PM
Ashish's Avatar
Send a message via AIM to Ashish
I'll just throw some stuff out there. There is a seal for your drive shaft, that could have been ruined when putting the drive shaft in. Also if you put a new TC in you should change the seal behind converter. Thats all I can do for you, put the tranny is a complete rebuild so I don't know why a seal would leak.
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #4 of 4 (permalink) Old 03-30-2004, 10:17 AM Thread Starter
How bad was it before? Well, put it in terms that I understood. It felt like I had a 3000 stale on my converter. When I read the troubleshooting artical about tranny problem. My old tranny had every problem that it listed. Not to mention it was so hot that if I places my leg agianst the hump, I could feel the heat radiating off the carpet. It was bad...Eric
P.S. The leak I had was from my fill tube. The o ring had severed and was not even there. I still have one drop about the size of a quarter. But I figure I will eventually fine the problem...
2011 Kia Sorrento
1996 T-bird
