trans mod question???? - TCCoA Forums
post #1 of 1 (permalink) Old 03-30-2004, 10:43 PM Thread Starter
after reading about the jmod and valve body mod ,i have a couple of question about modifying the valvebody,it says to get a 1999 valvebody, well i have one but its from a 2000 f150 with a 4.2 engine,will this valvebody work in a 97 mark?if not can i change the higher 2-3 capacity valvespring,lower capacity 3-4 valve spring and revised manual valve,from the 2000 valvebody into my existing valvebody?is there anything else i should change?thanks
blue_t is offline
