Tranny Fluid level - TCCoA Forums
post #1 of 2 (permalink) Old 04-05-2004, 02:48 PM Thread Starter
Send a message via AIM to chrisnack
Tranny Fluid level
if you are coming up about 1/2-1" over "hot" on the dipstick when the car is running, how much over do you think that is?
I know i put too much in, because i had no clue how much was already in the marauder TC when i filled it. I drained a bunch out (i have a drainplug) and guessed, but I'm still a bit high.
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #2 of 2 (permalink) Old 04-06-2004, 02:46 PM
Geek w/Gearhead Complex
Fubarian's Avatar
Leave it sit over night and check it cold (make sure its running) and see where you are on the stick. If you're still high, then drain some, start with 1/4 to 1/2 quart.
I'm assuming all other variables are null (you were on flat ground)
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
