What went worng with my trans. - TCCoA Forums
post #1 of 6 (permalink) Old 04-06-2004, 09:24 PM Thread Starter
Pulled my tranny out tonight oil was burnt and almost black. Now the weird part the fluid in the cooler was red and not burnt. I had this thing rebuilt with a level 10 kit by a ford trans tech. It lasted a whole two months.
Derek.L
Derek.L is offline
post #2 of 6 (permalink) Old 04-06-2004, 09:26 PM
Traveler's Avatar
I don't really know. but just guessing it sounds like the fluid wasn't getting to the cooler and it overheated big time? Anyone?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 6 (permalink) Old 04-06-2004, 09:27 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Sounds like something was blocking the flow of the fluid. I bet that thing was running HOT, not surprised it only lasted 2 months. Did they give you any kind of warranty?
Sold = 96 Thunderbird
Aaron K. is offline
post #4 of 6 (permalink) Old 04-06-2004, 09:57 PM Thread Starter
Nope, no warranty it was built on the side by the tech. I'm headed down to south Fl on Friday to get a 97' Mark IIIV trans.
Derek.L is offline
post #5 of 6 (permalink) Old 04-07-2004, 09:09 AM
392Bird's Avatar
I would disconnect the cooler lines at the trans, and check them for free flow. The red fluid in the cooler and very dark fluid in the trans would indicate either a problem in the trans causing no flow, or a obstruction in the thans cooling system. Get if confirmed before you install another trans.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #6 of 6 (permalink) Old 04-07-2004, 10:20 AM
You might have to replace the rad too, unless you bypass the stock rad cooler and install a good aftermarket one.
bigbird is offline
