strange trans problem while at wot - TCCoA Forums
post #1 of 6 (permalink) Old 04-12-2004, 05:04 PM Thread Starter
Chknhawk97's Avatar
Okay, I am probably sure that some one has posted this problem before but unfortunately I have failed to find the thread. I am driving a 97 Tbird, with no mods to date, the problem is that while driving over and intersection with a little bit of a hump (nothing to horrible but just an average intersection), off the line, I am at WOT, As soon as I get to about 4500 rpm, the car shifts to 2. Sounds normal Right, but it doesn't take in 2, it is almost as if i put the car in neutral, or like it just slipped gears? i have just recently had my fluid changed to mercon V, and no problems for about 500 miles, and now this. Any help would be appreciated, I am wondering if my TC isn't going bad.
Chknhawk97 is offline
post #2 of 6 (permalink) Old 04-12-2004, 05:47 PM
double-check your tranny fluid level....after running the car for a while shortly after a drain/refill, it will sometimes go low and cause it to slip
95ThundaChik'n is offline
post #3 of 6 (permalink) Old 04-14-2004, 09:10 PM
Ashish's Avatar
Send a message via AIM to Ashish
mine use to do the same exact thing, it was completly normal till I took it to WOT, well changed the fluid and the filter and all good. How many miles on your tranny. Since you did a fluid change recently have you checked if you are not leaking anywhere, maybe you filter fell in the pan.
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #4 of 6 (permalink) Old 04-16-2004, 06:59 AM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
same happened to me, changed fluid and filter, no more problems, fluid looked like mudbutt. filter wasn't much better.
Audiobahnbird is offline
post #5 of 6 (permalink) Old 04-16-2004, 01:17 PM
3rd Gear Chirper
hotbird's Avatar
Hmm, sounds like maybe your filter fell down into the pan. I always safety wire mine onto the valve body. When I failed my old trans I pulled the pan and found the filter sitting there in the bottom of the pan, so now I just use safety wire.
hotbird is offline
post #6 of 6 (permalink) Old 04-17-2004, 01:45 PM Thread Starter
Chknhawk97's Avatar
thanks for the info, i have only about 750 miles on it sinc i changed out the fluid, i will check out the filter and see if it is in the pan. Oh and as for mileage on the tranny, i am sitting at 120000, with to my knowledge, only one fluid change (the one that i did).
