Mark VIII Traction Assist Operation - TCCoA Forums
post #1 of 3 (permalink) Old 04-14-2004, 07:58 AM Thread Starter
Post Mark VIII Traction Assist Operation
As promised yesterday, here is an analysis of the traction assist as they pertain to the Gen I and Gen II Mark VIII’s.
The manuals I used were for a 96 Mark VIII and 97 Mark VIII (I couldn’t find anything in my 94 T’Bird manual that discussed Traction Assist, but it was getting late, so I didn’t look real hard. ) If anyone has information on the SC Traction Assist/Control, please post. Also, I'm doing this from memory since I didn't want to lug the huge manuals to work. So don’t quote me on the actual times (but the theory is correct).
They both work the same way mechanically with the Gen II’s having controls into the PCM that the Gen I’s does not.
On both Gen I and Gen II:
When the ABS system recognizes wheel spin on either of the two rear tires, it closes a valve, which isolates the front brake system from the two rear brake lines. The ABS pump then applies brake pressure to the offending (spinning) wheel. This then transfers more power to the wheel that is not spinning. (I need to double check and see if it is both wheels that get locked or if it does modulate the left and right)
While this is happening the front brake system is working as normal. If the brake is pressed while the Traction Assist is active, the ABS system immediately disengages the Traction Assist and everything reverts back to normal.
If continued wheel spin is detected, the system will only work for approximately 10 seconds and then disengage to keep the rear brakes from overheating. It also has some built in timers to avoid repeated heating of the rear brakes.
Here is where the Gen II differs:
The ABS/Anti-Wheel Spin module has inputs to the PCM/ECU/EEC (or whatever you want to call the computer ) and removes fuel and spark to unload the engine. They call it “reducing torque” as to not fry the rear brakes.
I knew it removed spark, but I didn’t know that it also removed fuel. It is VERY noticeable in my 97 LSC as it feels like it almost dies if I try to spin with the TC enabled.
Anyway, I just thought I would post that. This is just basically a regurgitation form the OEM manuals.
Hope everyone enjoyed.
p.s. My axle code on my 97 is "34"
69 F100 LWB w/460 Engine
post #2 of 3 (permalink) Old 04-16-2004, 01:11 PM
3rd Gear Chirper
hotbird's Avatar
Nice write up you have, that's interesting. Does the ABS module communicate over a data bus, or are the inputs directly wired to/from the ABS/PCM modules?
hotbird is offline
post #3 of 3 (permalink) Old 04-16-2004, 03:16 PM Thread Starter
I'll have to check that.
On the Mark, who knows!!
Sometimes they use the data bus, sometimes they use hard wiring.
I'll dig out my EVTM for the Mark and see if I can find anything.
