Pumpkin rear gasket - TCCoA Forums
post #1 of 9 (permalink) Old 04-16-2004, 06:28 AM Thread Starter
Pumpkin rear gasket
Going to change all the oils and fluids this weekend...
There's just one thing I need to now before I
order everything...
The gasket in the rear of the pumpkin...
Is it okay to order any gasket for a 8.8" Ford pumpkin
or are ours different since it's an IRS pumpkin... ??
Thanks!
//Thyg0d
Thyg0d is offline
post #2 of 9 (permalink) Old 04-16-2004, 01:20 PM
not sure.. If you were in a bind there is always a tube of Gasket maker
SkunkWorks is offline
post #3 of 9 (permalink) Old 04-16-2004, 01:29 PM
fast Ed's Avatar
There was no gasket installed from the factory, Ford doesn't even sell them. Just use some good quality RTV sealer.
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #4 of 9 (permalink) Old 04-16-2004, 01:31 PM
.. I like his idea better....
post #5 of 9 (permalink) Old 04-16-2004, 03:17 PM Thread Starter
Really..? No gasket???
Strange...
Well I've got a large tube of gasketmaker
from Loctite.. When I bought all the stuff I actually got a
Felpro gasket for an 8.8 inch Ford rear...
Not sure if it fits though..
Thanks a lot for your help!
//Thyg0d
Thyg0d is offline
post #6 of 9 (permalink) Old 04-17-2004, 12:11 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
they have one listed in the ford racing catalog.
2014 GT
1990 300ZX TT
big mike is offline
post #7 of 9 (permalink) Old 04-17-2004, 10:46 AM
fast Ed's Avatar
When I said "Ford", I was referring to their regular replacement parts division. Ford Racing sells one that is supplied by an aftermarket vendor.
cheers,
Ed N.
fast Ed is offline
post #8 of 9 (permalink) Old 04-19-2004, 01:14 AM Thread Starter
Thanks for your help!
No problems in using the new gasket...
HOWEVER!
It took me 5 hours to get the U shaped holder off...
I've been working on cars up to 35 years old but I've never
found anything that stuck!
I mean, ususally they do loosen a bit when you
heat it with a blow torch...
Ended up cutting the bolt...
Well... There's a new one on there so everybody's happy...
//Thyg0d
Thyg0d is offline
post #9 of 9 (permalink) Old 04-19-2004, 01:38 AM
Cougar Pilot
BlackCat94's Avatar
My mount was also very much seized on there. I sacrificed a 12"+ new Blackhawk ratchet, a socket, and then finally the bolt itself broke. Garage still smells like gear oil. mmmmm
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
