Just Installed B&M 24K cooler... - TCCoA Forums
post #1 of 18 (permalink) Old 04-20-2004, 12:19 PM Thread Starter
Ok well I finally completed the install of the cooler on my car. There are a couple of things that are a PITA.
This is what was done when I was finished...
Unscrew Top line, Cut of the 5/16th fitting on the hard tranny line. Slip about 8 inches of rubber hose over it and hose clamp it in Three places. ( I was going to flare it and make it all mint but the flare tool I borrowed was not getting along with me).
Now for the connection to the rad.. You have the Rad, Then a Fitting that goes into the rad, and then a fitting that goes into THAT fitting that you slip the hoes onto and clamp down...(follow me?) This is where people seem to have a lot of problems.. mainly because the Brass fitting that screw into the rad's fitting does not fit properly. What I did was unscrew the fitting that screws in to the rad (stock from ford) and I bought a "1/4" Pipe thread" brass adapter, barbed end on the other side for the rubber hose to slide onto, and screw that directly into the rad. (The 1/4" brass I bought was actually for a rubber air hose for like a air gun...)
Now everything is nice and snug and finally no leaks!!! Also a little tip remove the fan/fan shroud it is 2 bolts and a clip for the fan easy to take out and might save a few layers of skin on your hands.
I used about 13ft of hoes when all said and done with it.
Here are some pics so you can see where I mouted the cooler and what not....
Mounted on Drivers side, Drilled 2 holes and mouted useing included bolts.
I bent the cooler down a bit so it would catch a little more air.
Here its not blocking the PS cooler and the rad is still getting a lot of clean air... (White walls in baby lol)
Whoa look.. a cooler...
The red lines are just so you can see how I routed the hose...You can't really see the lines because they are under some wires.. but they are there.
You like..? I like..
I know I know I need to clean under the hood....
SkunkWorks is offline
post #2 of 18 (permalink) Old 04-20-2004, 12:34 PM
MaleWhore
smokymance's Avatar
looks nice...i still dont understand the pic u have the red lines on where the tubes pass through the back of rad to the front...
smokymance is offline
post #3 of 18 (permalink) Old 04-20-2004, 12:38 PM Thread Starter
..huh..
The red lines are just to give you an idea where I ran the lines...
post #4 of 18 (permalink) Old 04-20-2004, 12:43 PM
MaleWhore
smokymance's Avatar
yea...i was just wondeing if u ran them to the side...it looks like it...i was looking at my car today and its very very tight next to the radiator...i just need some ideas on how to run the tubes upfront of the rad
post #5 of 18 (permalink) Old 04-20-2004, 12:46 PM Thread Starter
Well its tight but not... Like the first maybe inch is have to push the hose down.. but below that (there is like a little piece of plastic sticking out..) there's is enough room to ensure that the hose is not pinched or anything.
post #6 of 18 (permalink) Old 04-20-2004, 01:11 PM
MaleWhore
smokymance's Avatar
ok kool...now if i go to a hardware store...can i just ask for a 1/4 fitting with a hose nipple on the back???? or what do i ask for
post #7 of 18 (permalink) Old 04-20-2004, 01:20 PM Thread Starter
post #8 of 18 (permalink) Old 04-20-2004, 04:58 PM Thread Starter
After looking at the pictures I spent a couple hours cleaning the engine bay.. Looks muuuuuuuch better now.
Well how is the install goign smokymance?
post #9 of 18 (permalink) Old 04-22-2004, 04:43 PM
GUS
So you tie into the top line? I always thought you would tie into the bottom one. If the top line has the hottest fluid, wouldn't you want to catch it comming out of the heat exchanger the into the aux cooler then to the tranny?.
GUS is offline
post #10 of 18 (permalink) Old 04-22-2004, 04:45 PM Thread Starter
The top line is the return line back to the tranny.
Thats where me and everyone else has put there cooler.
post #11 of 18 (permalink) Old 04-23-2004, 08:32 AM
GUS
If the return is the top, that means the lower has the hottest fluid. So I would need to install my gauge in the lower line, then the cooler in the top line. Correct?
GUS is offline
post #12 of 18 (permalink) Old 04-23-2004, 09:06 AM Thread Starter
I would think that to be correct. I do know that the Top line is the return line on my car. I am pretty sure it is the same for most models. The best thing to do is do a search and make sure the info is correct.
post #13 of 18 (permalink) Old 04-23-2004, 09:29 AM
GUS
lol, that is what I am trying to do . I have a Mark VIII, so I wonder if it would be different.... Thanks for the info, anyway.
GUS is offline
post #14 of 18 (permalink) Old 04-24-2004, 03:33 PM
MaleWhore
smokymance's Avatar
just got it done finaly...after being sick for almost the whole week...one more final question...how much more tranny fluid did u add...i so far threw in another bottle and im gona recheck it later too....
here is some pics
linky
post #15 of 18 (permalink) Old 04-24-2004, 07:47 PM Thread Starter
uh.. until it full...? :P
I put in atleast 1L maybe a smidge more...
post #16 of 18 (permalink) Old 04-25-2004, 12:56 AM
MaleWhore
smokymance's Avatar
yea...well im make sure its pretty topped tomorow again...
now i need to get a temp gauge wired in for the tranny temp...any ideas
post #17 of 18 (permalink) Old 04-25-2004, 01:05 AM Thread Starter
I need to do that aswell.. I know a buddy that put one in... but hes a machinist so he made his own T fitting heh..
post #18 of 18 (permalink) Old 04-25-2004, 02:10 PM
MaleWhore
smokymance's Avatar
the mechanical work doesnt bother me...i wouldnt know what to do with the electrical wiring...
