Possible MLPS problem? - TCCoA Forums
post #1 of 15 (permalink) Old 04-20-2004, 01:40 PM Thread Starter
The past few days I transmission has been slipping when ever I was in 4th and would go to WOT. Also when I would come to a complete stop the trans would slip as it was looking for 1st.
Now for the wired part. If I hit the O/D button the car no longer slips when I'm at a stop. Obviously I don't have the problem of it slipping when I'm at speed because it's not in 4th.
So does it sound like the MLPS, please say yes, or am I in for a much more expensive problem.
cars a 96 3.8
Jemplayer is offline
post #2 of 15 (permalink) Old 04-20-2004, 01:59 PM
What does it do when you are at a complete stop? When my MLPS went south, i would be driving and the Car would just downshift to 2nd, or shift into N then it would go back into gear.
Green95LX is offline
post #3 of 15 (permalink) Old 04-20-2004, 05:04 PM
I have no idea what it would be .. but His problem does Not sound like a MLPS problem... sounds like a costly one.. : /
Checked fluid lately? hows it look...
SkunkWorks is offline
post #4 of 15 (permalink) Old 04-20-2004, 05:20 PM
Every once in a while, my car will seem to jump out of gear when I'm at a dead stop, but if I take off in 2nd, no problem. Does that sound like an MLPS?
Rich95XR7 is offline
post #5 of 15 (permalink) Old 04-20-2004, 09:02 PM
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
My car has been starting to do the same thing. It'll just downshift or shift into neutral when I'm just barely touching the gas. If I get on it then ther is no problem.
"Technical skill is mastery of complexity while creativity is mastery of simplicity."
94t-birdlx is offline
post #6 of 15 (permalink) Old 04-20-2004, 11:43 PM Thread Starter
It's not the MLPS.
I did the 4th to 2nd at 60mph test and it falied.
I'm now a firm beliver in an external trans cooler, mecon v, and the j-mod. 90,000 is just to soon. Dam delivery driving.
post #7 of 15 (permalink) Old 04-21-2004, 09:39 AM Thread Starter
Well since I'm going to be replacing the transmission is there any good torque converter replacments for a v6?
post #8 of 15 (permalink) Old 04-21-2004, 01:37 PM
my 94 w/3.8 did pretty much the same thing. found metal shavings. but the mlps was also changed.......according to the invoice. see if changing the mlps is a easy task. if it is change it. if it still acts up, at least you'll have a new mlps installed.
nene is offline
post #9 of 15 (permalink) Old 04-22-2004, 10:56 PM
FordFanatic's Avatar
yeah its pretty easy, couple of bolts and a wiring harness.
FordFanatic is offline
post #10 of 15 (permalink) Old 04-22-2004, 11:18 PM Thread Starter
Yea the MLPS is easy to change took me 15 minutes. Unfortunatly that didn't do anything.
post #11 of 15 (permalink) Old 04-22-2004, 11:43 PM
Lazania's Avatar
The Mark 8 TC should be perfect for you. cheap and does the job, Ill say this do not get a Dayco TC I went threw 4 of them before I told my tranny guy that I wouldnt put another in and we went with the Mark 8 after it was rebuilt again under warrenty because the original TC broke apart burning up my tranny.
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #12 of 15 (permalink) Old 04-23-2004, 12:00 AM Thread Starter
I can fit a mark VII T/C on a v6???
explain?
post #13 of 15 (permalink) Old 04-27-2004, 10:35 PM
Ok, here's my two cents..... My 94 LX did the same thing (jumped to neutral at 60 mph). I R&R'd the MLPS, no help. Next, installed a Trans-Go kit and bingo! It's fixed! My point is, I doubt it's an electrical problem.
Good luck.
wrench71 is offline
post #14 of 15 (permalink) Old 04-28-2004, 07:25 AM
I think you may have just temporarily covered up one problem, and started another.
post #15 of 15 (permalink) Old 04-28-2004, 09:18 AM
Yeah....
I don't have anyidea what the problem is now... Atleast it hardly ever does it.. (knock on wood)
