cobra differential? - TCCoA Forums
post #1 of 15 (permalink) Old 04-21-2004, 12:42 AM Thread Starter
cobra differential?
can i swap the whole differential from an 03 cobra into my 89 supercoupe?
89sc5spd is offline
post #2 of 15 (permalink) Old 04-21-2004, 02:01 AM
I don't think the splines would match up, the Cobra has 31 spline and the MN12 is 28 spline.
Green95LX is offline
post #3 of 15 (permalink) Old 04-21-2004, 06:49 AM
I did it, but I had to have the side gears swapped out
from 31 spline to 28 spline.
Mike Donley
Mike Donley is offline
post #4 of 15 (permalink) Old 04-21-2004, 07:34 AM Thread Starter
how do i swap them? where can i get them?
89sc5spd is offline
post #5 of 15 (permalink) Old 04-21-2004, 08:59 PM
It involves taking the differential apart, so I would have a dealer or
a shop do it. The side gears would have to be purchased from a
dealer or someone who sell reart end parts. They must be IRS side gears,
because they have groove machined in them to allow the circlip on the
end of the axles to snap in.
Mike Donley
post #6 of 15 (permalink) Old 04-21-2004, 10:27 PM
Pedal Faster
Josh_Keady's Avatar
Would it be easier to create a set of hybrid half-shafts that have the 28 spline Tbird hub style on one end and the 31 spline Cobra IRS style on the other? Or is that going to be more money?
Josh Keady
Josh_Keady is offline
post #7 of 15 (permalink) Old 04-21-2004, 10:33 PM
PostSkank
StupidFly's Avatar
I'm pretty sure a "bolt on" (thats what the side gear change sounds like) is gonna be less expensive than having custom shafts made.
math > pasta
StupidFly is offline
post #8 of 15 (permalink) Old 04-22-2004, 05:46 AM
joshbea6's Avatar
Look at the group purchases. There is a GP going on that will have the 31 spline inners and the 28 spline outers.
joshbea6 is offline
post #9 of 15 (permalink) Old 04-22-2004, 05:56 AM
Jedi Master
mn12xr7's Avatar
if you want a cobra one get a 99 or 01 diff.
-Orlando
mn12xr7 is offline
post #10 of 15 (permalink) Old 04-22-2004, 06:00 AM
I thought it was only the 99's that had 28 splines, and that after 99 they changed to 31?
post #11 of 15 (permalink) Old 04-22-2004, 06:13 AM
Jedi Master
mn12xr7's Avatar
i do believe it was in 03 if i am not mistaken
-Orlando
mn12xr7 is offline
post #12 of 15 (permalink) Old 04-22-2004, 06:36 AM
Not to argue here, but refer to this thread
http://forums.tccoa.com/showthread.p...threadid=11296
It's said that only the 99's have the 28 spline side gears
post #13 of 15 (permalink) Old 04-22-2004, 07:31 AM
'99 only had 28 spline. If you get one cheap, and need the side gears, Call Dan, he found the side gears for Ozzman, I think they cost $70 though.
Rich95XR7 is offline
post #14 of 15 (permalink) Old 04-22-2004, 09:14 AM
Jedi Master
mn12xr7's Avatar
I just asked my friend who has a 01 Cobra, and Green95lx you were right, I stand corrected
-Orlando
mn12xr7 is offline
post #15 of 15 (permalink) Old 04-22-2004, 10:01 AM
Hehe, It's all good. We all do it, from time to time.
