vibration/noise at speed - TCCoA Forums
post #1 of 5 (permalink) Old 04-27-2004, 10:22 AM Thread Starter
'97 4.6l stock, bilstein shocks, Firestone Firehawks, stock rims
A few months ago my bird starting having a drive problem. When I get up to about 50mph and then release the gas, I get a vibration that continues until I throttle up again.
At about 65-80MPH I get a very annoying, low frequency noise, kind of like road noise from tires. When I get accelerate, the noise goes away for a second or two and then comes back.
Took it to my local tranny shop. They did a test drive. They think it might be a problem with one of the half shafts but they can't get it on the rack for another week.
Anybody have any other ideas what this would be?
DanB is offline
post #2 of 5 (permalink) Old 04-27-2004, 11:04 AM Thread Starter
Forgot to ask.
If I do replace the half shafts, should I use OEM or aftermarket?
DanB is offline
post #3 of 5 (permalink) Old 04-27-2004, 12:52 PM Thread Starter
$380 for new, $120 for rebuilt from my local dealer
DanB is offline
post #4 of 5 (permalink) Old 04-29-2004, 11:07 AM Thread Starter
Turned out that one of the rear u-joint bolts had worked loose.
DanB is offline
post #5 of 5 (permalink) Old 04-29-2004, 12:52 PM
Trumpeter Extraordinaire
IronChopz's Avatar
When I read this post the other day, I wondered if it was U-joint related - I started reading the Noise/Vibration section of the 1997 Service Manual for ideas. It's interesting that a bolt had worked itself loose (you're referring to the yoke-to-flange bolts, I take it, that are at the rear end of the driveshaft). When I was replacing U-joints several weeks ago, I had a very difficult time undoing the bolts at all (I broke a wrench during the process!!!), so much so that I waited another couple weeks and went after them again. The replacement U-joints made a huge difference in dampening/controlling the vibration (I've had the car up to 95+ without a hint of shaking).
Glad to hear it wasn't a pricey "repair."
IronChopz is offline
